Offfers no pc angel recovery option, not showing all users on startup, only showing 1 user(me). my wifes and guest account not there on startup?????? how can i fix this with out reloading os or losins pics and docs
In the run: type in msconfig that should load all your orginals back to normal but it sounds like your computer might be infected by malware because it's hiding your icons you use on a everyday basis. once there in msconfig hit normal not dianositc.
I will try this ,
Ty very much ,
Eric
I tried that , did not work.
Started same way .
Thanks for trying !
Eric
Got it fixed,
Ty for your help
Eric
SOURCE: cannot access pc angel protected recovery partition files
can u please describe the issue more
SOURCE: Our PC Windows XP/Dell Dimension E310 was attacked
Ensure your Keyboard is set to your proper language, Under Control Panel, Regional and Language Options!
SOURCE: Delete emachinesSystems Recovery and Angels Systems software
You should be able to simply uninstall it in the control panel add and remove programs
Start > Control Panel > Add And Remove > locate the entry relating to the application you wish to install.
SOURCE: how to put the recovery partition back on the emachines t5048
As far as i know the only way is to run the restore disk from emachine that is for your model computer. (it usually wipes the computers hard disk in the process.)
the link below will take you to their support site for drivers.
on that site look for eMachines Recovery Media Purchase Program and you can see about ordering the recovery disk that you need.
http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5048
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
