Question about Thetford N641
Frigde freezer i have a frost free hotpoint frigde freezer and the contents in the frigde keep freezing up
  • Ken Bledsoe May 11, 2010
    What is your t-stat set at?
  • Thetford Master
  • 4,654 Answers
Sound like door seal is not closing tightly allowing moisture to be drawn in and freeze the contents. Below is a link with Q&A and solutions. Try this link and get back with us to help you get this fixed. Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
Hotpoint ffa91 My frige is freezing everything I put inside it.
sounds like the door between the freezer and cooler is stuck open
Jan 23, 2014 | Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Hi Guys, I have a frigde that was brought in 2002
HI,
Please check your compressor and thermostat for malfunction then.
Regards
Feb 27, 2011 | Fisher and Paykel Active Smart E522B...
I have a hotpoint frostfree freezer that is over
Since this is a frost free refrigerator/freezer, you shouldn't need to defrost it, and the frost should not be building as you describe.
If your OK with diagnostic troubleshooting techniques, and have a volt-ohm meter and know how to use it, we can figure out whats wrong with your unit.
Dec 16, 2009 | Hotpoint Ultima WF860 Front Load Washer
Freezer not freezing
when the freezer is not freezing, check the fan and fan motor in the freezer section. It should be running when the compressor is running. Check for frost. If you see frost on the rear inside panel, the frost is usually about 3 in. thick on the inside. Check and make sure the fan next to the compressor is running, if your's has one. It will run when the compressor is running. Check for gaps in your door gasket. If there is no frost, both fans are running, compressor is running, and no gaps, and your coils outside the refrigerator are clean, it doesn't sound good.
May 04, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Open Questions:
Thetford N641 Logo
119 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
