Whirlpool Cabrio  WTW6600SBT Top Load Washer
Problem for Whirlpool Cabrio WTW6600SBT Top Load Washer
F 32 code problem
By soohyrussell on Feb 01, 2009
My washer stops after 17 minutes and an F 32 code appears. I need to find out what is wrong. Any ideas?
Solution #1
posted on Oct 29, 2009
Not Rated)
mrgomes
Rank: Apprentice
Rating: 0%, 0 votes
Mine had F51 and F32. After reading the solution #1 I checked the drain pump for any clogging but it was a broken wire (blue) in the pump connector. It was (long but) an easy fix, because the connector is IDC and we just need to open the cap, take out the remaining wire piece, reposition the wire in the blade and close it again, using a pipe plier. It's back to life.
Was this helpful?
Yes
No
Solution #2
posted on Feb 03, 2009
Not Rated)
tzweeb
Rank: Guru  Whirlpool Expert
Rating: 92%, 151 votes
f32 is a code for a long drain. what you need to check is that you are using the right soap, HE type, and that when the unit is done that no water is left ion the unit.
if you do have water, then you will need to check the hose going into the drain pump from the tub, you might have something blocking the pump from getting water into it and that will cause a long drain and then the failure code.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Cabrio WTW6600SBT
Questions and Unsolved Problems for Whirlpool Cabrio WTW6600SBT
Do you recommend Whirlpool Cabrio WTW6600SBT Top Load Washer?
Answer
Answer
Toward the end of the wash cycle, my whirlpool cabrio has started making a very loud crackling... (More)
Answer
I push start and the F letter comes on and the dial lights up. It does not work!
Answer
Washer keeps displaying code UL even when the washer is in balance.
Answer
The washer keeps stopping and beeping during the wash cycle.
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
