Question about Mackie SWA1501 Subwoofer
Bass pops hello i have a swa1501 powered sub by mackie,it has worked great for about 7 years but on my last show it started having a intermittent pop sound.i powered off and back on but problem was still there,i even unhooked the cable to it and it still continued to pop.any help would be greatly appreciated.
    Problem Solver:
  • 8 Answers
Hi There, Have you checked the 3 fuses that clip onto the main amp board? You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should have eradicated the popping. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Posted on Mar 24, 2009
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
I have a hole in my mackie sub How can I get a
See the link below to either locate a dealer close by or to contact Mackie directly for the parts.
Dan
Link: http://www.mackie.com/support/
May 09, 2010 | Mackie SWA1501 Subwoofer
Huge popping noises intermittantly at low volume...any suggestions?
Does it still make the noise if all inputs are disconnected? ...to try and determine if it is internal or externally caused...
Mar 29, 2010 | Mackie SWA1501 Subwoofer
Any idea why my Mackie swa1501 bass bin has blown 2 speakers in the last 3 months? Bass Drum is the heaviest instrument going through it, but I never let it clip, I also run a fan on it which keeps it...
does your swa1501 get hot just being switched on ?
sounds like your output transistors breaking down or your dc to dc rectifier is shorting this would dumping high voltage to the speaker. I guess your speaker coil is burnt . check Q4,Q5,Q7,Q12.Q14,Q15,Q17 and Q18 these are all mosfet transistors that commonly break down..
Oct 01, 2009 | Mackie SWA1501 Subwoofer
Where to purchase a bracket
Unfortunately there are two standards for the pole diameters. Some of the smaller poles have caps to accomodate the larger brackets. First thing is to measure what you have for poles and the two sizes of mounting holes. Many of the mounting bosses are standard and available online here is an example:
http://www.amazon.com/Speaker-Cabinet-Metal-Stand-Mounts/dp/B0035AJTL8
Sep 19, 2009 | Mackie SWA1501 Subwoofer
Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Jul 31, 2009 | Mackie SWA1501 Subwoofer
Sw 1501 no sound output
in my dvd dts audio is not playing
Feb 13, 2009 | Mackie SWA1501 Subwoofer
Sub will not power.
I reckon there is a good chance you've got a dodgy mains transformer, or perhaps a blown internal fuse. Sounds very much like the problem is on the AC input board.
May 22, 2008 | Mackie SWA1501 Subwoofer
Round bass
get a bass amplifier and connect to the subwoofer.
Apr 14, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
257 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
