Question about Sony Playstation 3 (PS3) Console
No audio when streaming mp3 to PS3 via NAS
I have updated dlink DNS-323 firmware to 1.06 (which now supports PS3 and Xbox360). i have configured my ps3 to communicate with NAS and it works perfectly, but when i come to play an mp3, there are no audio and no error pops up.
Is there something i'm doing wrong?
Cannot access documents on dns-313
I'd try two things. Boot in Safe Mode with Networking and disable all firewalls, see if you find the NAS. Your issues sure screams firewall configuration to me.
Apr 21, 2012 | D-Link DNS-323 (DNS323) Hard Drive Array
I have a panasonic G20 TV with wireless connection to my network. there no problem accessing vieracast (the internet connection is working). I have a NAS (DLNA) drive connected to my router. PC's find...
i am having a similar issue with my Panasonic G20 and Dlink DNS-323 NAS drive. I installed Twonky 6 and it worked for a short while and now does not even list the server in the list of the TV. Anyone else know what NAS drives are compatible with this TV?
Mar 09, 2011 | Televison & Video
D-Link DNS 323 Bittorrent doesn't start
Make sure that the ports for the application are open in both your modem and router
Dec 29, 2009 | D-Link Dns 323 2-Bay Network Storage...
Hello, I just bought DNS-323 and trying to start up it. I?m using one hard drive Seagate Barracuda 7200.10 ST3500630AS SATA 3G HDD 500G. I installed it in HDD1 slot and start the system. DNS-323 received...
I read that there are problems in some applications if you use only one disk in the 323. Try to move your disk to the other slot to see if this fixes your problem. Alternatively (if u have the money), you can try buying another hard disk of same brand/model and install it on the other slot.
You can then try setting up your device as a RAID1 or bigger (not recommended) JBOD configuration
Nov 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
Lost wireless internet to our MAC OSX 10.5 Resetting ISP didn't help. Running Network diagnostics didn't help. Our ISP, Telus says it isn't their problem. Wireless is working on our non-MAC computer. It...
Did this occur after an OS update was installed? There's some history of dropped connections due to Mac updates...Check the Dlink site for firmware upgrades for your router, and install them, and see if that fixes it...
Aug 18, 2009 | Computers & Internet
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Bittorrent configuration problem
The new firmware already has bit-torrent capabilities built into it. Please do the following:
1. Download the latest firmware from D-Link website
2. Save your configuration in case there are any problems
3. Upgrade firmware from the DNS-323 menu
May 05, 2009 | D-Link Dns 323 2-Bay Network Storage...
Ftp and upnp problems with dns-323
Try to do the following:
1. Login to your DNS-323 in the same network
2. Make sure FTP is turned on and a user is configured to perform FTP to it
3. Ftp to your DNS-323 using the admin account
If this still does not work, read up on Fonz's fun_plug application and install it. This should let you access the linux firmware in the 323 for troubleshooting. Be aware that you need to know linux before you attempt to do this as you may brick your 323 if you are not careful.
Mar 17, 2009 | D-Link Dns 323 2-Bay Network Storage...
Sony Playstation 3 (PS3) Console Logo
143 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
