Question about SDAT HTA6SD System
Dvd disc drive wont open
I have a sdat hta6sd home theater system we were watcing a dvd when the dvd froze. we tried to eject the dvd but nothing happened.we turned the power button off and back on but still can get the dvd to eject. even leaving the unit off for several hours then turning back on did not help. Any suggestions?
    Problem Solver:
  • 10 Answers
Unplug the power cord for ten min. then try again.............. John
Posted on Feb 01, 2009
If press eject button,it's showing LOCKED.what can i do?
You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Jan 21, 2015 | home Audio Players & Recorders
Some DVD's dont work on my DVD player??!!
This worked for me (taken from the service manual)
Power on Unit Select Disc Then Open / Eject Then type the following...
9999 followed by *subtitle* followed by the region you want EG: Region 2 would be - 9999 *subtitle* 2
Works perfect for me :)
Mar 12, 2010 | Philips SoundBar DVD Home Theater with...
Dvd wont eject when you try to open it. or dvd wont play
i think the cd or dcd disc inside stuck-up you have to insert the tiny hole located at the dvd rom and insert a needle or something that is similiar or smaller of the hole size of that locted in your dvd rom.usually its new the LED blinking when opening or inserting the disc. and now you can now eject your disc manually regarding your question about it won't play a dvd try first to clean your DVD disc with a micro fiber cloth, avoid you'll scratch it, if still the same i think you're dvd room is defective.
Oct 08, 2009 | Bose (321GS) System
Dvd won't eject and picture froze
Try un-plugging the unit from the mains electric supply, leave it for a couple of minutes & then plug it back into the electric supply. This should re-set itself & hopefully eject the disc. If the disc had a bad spot or the laser did not traverse smoothly this will cause the disc to freeeze & lock up.
Jul 27, 2009 | Bose 321GS Series II System
Disc tray does not always open
well i understand why the remote won't eject the disk because there is no eject function button on the remote. The top pannel function button's are the only way to eject a disc on this system. on these units I have seen the button's go bad and need replacement. More likely the dvd section of the unit is starting to go bad. Bose has a reasonable factory repair rate. The drive swap is simple but requires some technical skill. Obtaining the drive is difficult as bose does not sell just the drive. I have listed myself and seen some listed on ebay for sale. I hope this helps. Dan
May 31, 2009 | Bose 3 2 1 GS Series II DVD Home...
Will not play dvd,will not eject dvd
We had the same problem and found we had a disc stuck in there... I stronlgy advise not to open it unless you have some idea on what to do. We opened ours and got the cd/dvd out and luckily it still worked!!!
Jul 24, 2008 | JVC TH-M303 System
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
SDAT HTA6SD System Logo
64 people viewed this question
Top SDAT Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDAT Audio Player and Recorder Expert? Answer questions, earn points and help others
