Question about JVC GRDX77 MiniDV Camcorder
I want to get the tape onto my pc - how do i do this. Is their a special lead i require, etc.??
  • col_t231 Feb 01, 2009
    Where can i get one from - do i just ask for USB minn connector in currys or somewhere like that?!
  • col_t231 Feb 03, 2009
    Sort of knew this but thanks for your advice!
    Champion:
  • 219 Answers
My guess is that you need a USB mini connector to connect the camera to your computer.
Posted on Feb 01, 2009
  • swufabuda
    swufabuda Feb 01, 2009
    Any major electronics store should have it. Just tell them what kind of camera you have and they should know,better yet take your camera with you when you go...
I have a VPW8OU vIDEO CAM CORDER. i AM WONDERING if I can play the tape onto my pc somehow
Tape video recorders are unfortunately old technology. Video sent to a tape is not a fully digital file in the sense that it is not read by computers and has to be captured when you play it back into the computer and turned into a video file. Unless you are savvy with computer connections and software requirements and are able to connect up the camcorder so that it is recognised by the computer AND capture software, the easiest way might be to get someone to put the tapes down onto a dvd for you. Many retailers advertise this service.
Aug 21, 2014 | Video Cameras
How hard is it to replace the elsectrical line leading into the fuse box?
You'll have to splice extra wire onto each conductor and seal both ends of each splice with special 3M tape to keep out moisture. You'll also have to match the wire gauge of each wire. Very tedious job, but doable as long as you take your time and don't take shortcuts.
Dec 04, 2017 | 2001 Buick LeSabre
Need software so i can download and edit dv tapes onto my pc so i can edit them and put them onto a DVD.
Use Windows Movie Maker it should be installed as part of the Operating System.
A firewire cable is required. 4 to 6 pin for most Desktops or 4 to 4 pin for most Laptops.
Mar 19, 2011 | JVC GR-D240 Mini DV Digital Camcorder
How do I load a canon ZR900 MiniDV camcorder's tape onto a Mac?
You require a firewire cable, 4 pin to 6in, these are also cazlled i link or IEEE 1394.
iMovie should be on your Mac, captue with that unless you have FinaL Cut, Adobe etc..
Al
Feb 11, 2011 | Canon ZR900 Mini DV Camcorder
What cable is required to download the recorded video on tape?
To download from the tape (not the memory card) you need a firewire cable, and a computer that has firewire compatibility. Most laptops have this, but desktops may require a firewire card to be installed.
May 05, 2010 | Canon Elura 100 Mini DV Digital Camcorder
How to adjust tracking on a DSR-11?
try to use you channel button up and down while playing tape.
Apr 27, 2010 | Sony DSR-11 DV / Mini DV VCR
Forgot service password for HP Surestore Tape Autoloader 1/9 DLT 1 Tape Drive
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Mar 08, 2010 | HP Surestore Tape Autoloader 1/9 (C7147A)...
Can SD Memory cards be used with my Go 720??
the "no SD required" is just letting you know that all of the important stuff to make the unit run is all on the hard drive of the unit itself. Yes you can use a SD card to hold maps, photos, or music. For instance if you were going to Europe, you will be able to get a European Map and download it onto the SD card. Another instance would be if you wanted to download some mp3 files.
Sep 28, 2009 | Tomtom GO 720 GPS Receiver
Transferring VHS-C tapes from a Panasonic NV-RX14B to my PC
Search Ebay for peripherals to transfer tape to PC - they come with all leads and software.
Mar 28, 2017 | Panasonic NV-VZ14 VHS-C Analog Camcorder
Video Cameras Logo
137 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
