Question about Nokia N70 Cellular Phone
Backlight solution Hi, i have nok 1600 in which d keypad light does not glow.So.. pls......... send me the technical fault and slution for it
    An expert whose answer gotĀ voted for 100 times.
  • 91 Answers
Re: backlight solution
Replace the small ic on the bottom of the board . and there may even be a track cut. display connector right hand 1st point to bottom to the coil
Posted on Aug 23, 2007
Re: backlight solution - Nokia N70 Cellular Phone Cell Phones
Posted on Sep 07, 2008
0 characters
3 Points
How do i fix nokia E63-1 display light automatic glow after some time?
Your set need to be casing keypad require clean-up
Dec 15, 2013 | Cell Phones
Hi, my nokia 5610 lcd module back light not working properly... but i press somee were on screen it is glowing. pls send me solution...........................
Feb 11, 2011 | Cell Phones
My nok 6300 phone bluetooth is not switch on
there must be some technical software problem in your mobile. kindly format the phone and try it. if still have same problem then there must be fault in connecting devices in your mobile. kindly change the connectivity device of your mobile..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Jul 26, 2010 | Nokia E71 Smartphone
I had for got my phones lock code number pls help to get it turn on my mobile model no is nok 1600
only flash box tools can read your scurity code. no need to flash, just read PM memory, also security can set to orignal factory code without loose your data. If you don't have, just send to your technician to do that, only few minute your problem will be setle.
Mar 21, 2009 | Nokia 1600 Cellular Phone
K800i no backlight or keypad light. it is not a firmware fault a i took it to a specialist and they tried flashing it but no luck, they told m it needs a new screen but if that is the case why doesnt the...
go to setting and hit on display and u shold see when u get there then look for backlight and keypad light hit on them and u will be able to do the rest its easy
Sep 12, 2008 | Cell Phones
Nokia keypad is not working
good day ! the problem of your phone is keypad main brain try to clean that or chagne the mainbrain ! good luck ! thanks ! ....
Sep 09, 2008 | Nokia 1600 Cellular Phone
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
Mar 30, 2008 | Nokia 1600 Cellular Phone
Nokia 1600 backlight switched off cant see a thing!! :( help!!
just pull out the batery without turn it off that will reset the original configuration
Dec 27, 2007 | Nokia 1600 Cellular Phone
Nokia N70 Cellular Phone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
