Question about Panasonic SC-DT100 System
PANASONIC Home cinema SC-DT100 - Flat cable connection
Do you think it's possible to use a common DVD reader with the amplifier SA-DT100 via flat cable? My DVD reader SL-DT100 is not working and i would like to replace it by another one (not PANASONIC)... Do you have the connection schema of the PANASONIC flat cable? Thanks a lot!
  • Anonymous May 19, 2008
    hi, i search the pin-out of the sc-dt100-receiver - dvd-player connection. i need it to serve a sat-receiver (5+1) audio signal to the sc-dt100-receiver.
    if you have additional schematics of the sc-dt100 - please send me by email (edu[at]at.e-technik.uni-kassel.de)!
    best regards edu
  • Anonymous Mar 15, 2014
    How to hook up to fiber optic cables
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Posted on Oct 09, 2007
SOURCE:
Am looking for a system cable for panasonic sa-ht880
i m searching for panasonic SC-HT880 home theater cinema scart cable........frm where i can get thiscb646a10-3dea-4114-b18f-0a8e843afcbc.jpg
Sep 27, 2012 | Panasonic SC-HT880 System
How do i connect my sytem directly to the tv not just the dvd player?
Connect to the audio out of the TV, assuming you have a RCA audio out (red/white) on the TV. (Audio out of the TV to one of the Audio in of the SC-DT100)
The manual for the SC-DT100 is available from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/model.SC-DT100 .
Some new TVs only have digital audio out, this isn't compatible with this home theater system's inputs.
I hope this helps.
Mar 09, 2011 | Panasonic SC-DT100 System
Panasonic SC-DT100 flat cable
ON SCDT100 has only TV/AUX IN the flat cable is only for Panasonic Devices, so you only option has TV/AUX IN,you need the comb. AV cable from WD media player and connect to TV/AUX INPUT
Jan 17, 2010 | Panasonic SC-DT100 System
Is it possible to connect an LG 5010 tv to a
Yes, you can connect any home system into the TV by either using a scart or HDMI connector to produce the picture on the TV. The sound will still be present through the cinema system
Nov 22, 2009 | LG 42LC2D 42 in. LCD HDTV
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
[email protected]
Jun 30, 2009 | Panasonic SC-HT740 System
Hook up
well u cannot hook almost any devices with the SC-HT500.
I have this homecinema system for 5 years now, and i had to buy another stand alone DivX player to hook it up, but can't get the sound in dolby from the standalone player since the panasonic SC-HT500 has only 2 analog stereo RCA ports (audio in) in the back and a scart (A/V out) and component video (Video out).
At that time it was a very good system, but since i have bought a Full HD LCD tv with 1080p capabilities, I realised that my home cinema system i.e the Panasonic SC-HT500 is kind of useless, in the sense that you cannot even change the player for another one since the whole spaker and power connections are made trhough a special cable from the subwoofer. :(
best solution is that put the system back in a corner and get a new system which is not an all-in-one system. Preferrable get home cinema systems that come with a receiver, separate dvd player and speakers and subwoofer hooked to the receiver.
you asked how to hook these devices to your tv,, well the panasonic dvd recorder is better if you connect it via HDMI cable if you can. In the other case, connecting them with a scart cable would be another solution.
Dec 02, 2007 | Panasonic SC-HT500 System
Panasonic SC-DT100 System Logo
930 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
