Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissell won't start
Belt was burning last time I used it - took belt off and now vacuum won't turn on. Is there a reset button? Bissell Powerforce (not bagless)
    New Friend:
  • 68 Answers
No reset (self resetting motor) Pull the plu,g leave it off for a day, plug it in a try it again tomorrow. If it doesn't work, the motor is gone
You also need to make sur ethat you get the vacuum back together correctly, some vacums put a swithc in there so that you can't hurt yourself while performing this repair
Posted on Feb 06, 2009
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Cant find reset button
Hey Troy, the PowerForce Turbo Helix doesn't have a reset button. You may want to have a Qualified Technician at at BISSELL Authorized Service Center inspect your vacuum.
Here's a quick link to assist you in locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 28, 2013 | Bissell PowerForce Turbo Helix Bagless...
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
My roller bush won't turn ever time i put a new
1) you need a little tight the belt, with the bolts of motor.
2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor.
3) the motor you must test for brush, switch, or open winding.
4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord.
God bless you
Jul 23, 2012 | Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Nov 03, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
Jan 09, 2008 | Bissell 3522 PowerForce Bagged Upright...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
363 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
