MOTHERBOARDS THAT CAN FIT A ADVENT T9102 CASE
I wont to upgrade my Advent T9102 but cant find any thing out about the case. Cab you help I need to no what motherboard will fit this case or am Iwasting my time.
  • Anonymous May 11, 2010
    You could always buy yourself a new case which will support your motherboard choice. Afterward just move the parts out of your old computer and stick them into your new computer.
    Just a few things you need to watch out for. If your current hard-drive and optical drive is hooked up through the typical ATA cable, you will have to buy a new hard drive and optical drive which is SATA compatible. You also need to make sure that your video card is a type that will fit a port on your new motherboard. Afterward you need to make sure that your current PSU will fit your new motherboard. Some PSUs only have a 20 pin connector while some motherboards require 24 pins.
    Just a few things to consider before upgrading. Just trying to make sure it works smooth for you.
    Let me know if buying a new case is not an option and I'll see if I can determine if your current computer's case is ATX or Micro-ATX.
    Sniper:
  • 86 Answers
The Advnet case you have is a micro ATX (mATX) case. I would suggest that you purchase an inexpensive ATX size case. You'll have more room to work and the potential for better air flow for cooling.
Posted on Feb 06, 2009
SOURCE:
How can i find audio drivers for an avent t9102 pc ?
www.adventcomputers.co.uk/product-support
Sep 07, 2014 | Computers & Internet
Were can i get a user manual for advent desktop pc model number 3408a
I know this isn't a manual but it's the best I could find. It tells more than just the specs and even how to open the case:
http://www.uktsupport.co.uk/advent/pc/3408a.htm
Hopefully it will help you...
Sep 04, 2012 | Computers & Internet
Advent 7109b battery wont charge
Yes! it is very possible, specs are different in none original power adapters, because it sounds like the charging circuits are working. I recommend getting the original adapter for your model.
Apr 19, 2012 | Advent Computers & Internet
How to reboot my laptop
You do not give enough details about what the problem is and why you need to reboot. Reboot simple means restart, but if the computer is frozen or will not start at all there are specific solutions.
Here is an advent support forum that may have answers for you.
http://www.adventsupport.com/
This page is about Advent desktop reboot but try these things anyway. The last step to take out the power means also taking out the the battery in the case of a laptop. Good luck
http://www.ehow.com/how_4815320_reboot-advent-computer.html
Dec 22, 2010 | Advent Netbook
Why my webcam is not working on my Advent Roma 3001
Well... in your case you have two possible solutions:
1. Download the driver on the oficial web of the equipment.
2. The webcam maybe it not compatible with the system on your netbook (if the cam connect by usb) or if upgrade the system. Ej. XP to Vista
Oct 20, 2010 | Advent Netbook
Upgraded to windows 7 cant find software for web cam i dont have cd,where can i find this software for advent 6651
W7 comes with thousands of drivers pre-installed. If it is compatable with W7 it will automatically install the required driver. Have you plugged it in and allowed W7 to try to install it for you? There are other solutions also if this doesn't work.
Dec 06, 2009 | Recoton Advent Advent Q2035A 20" TV
Need to open Advent 7072 case to resolder power jack socket...How?
This is something that should be left to a professional. A local repair shop should be able to handle this task easily. but if you insist you can try here
Apr 17, 2009 | Computers & Internet
I have a broken hinge on an Advent 4211 laptop, but cant find a replacement...Can you please help me..? Thanks Phil
Not knowing where you live, I'm not sure where to point you. But try this link online: http://www.ipc-computer.eu/?gclid=CKrVs7WcxJkCFQ9JagodhFQ3vA
If that doesn't pan out, browse this page and see if another supplier doesn't turn up...http://www.google.com/search?q=Advent+4211+laptop+parts&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Hinges are a tough thing to come by, I'm afraid.
You might check your local repair shops and see if they'd be willing to let you trade up to another laptop.. They could move everything over for you and you'd have the added rush of a newer machine.
Or you could apply the Red & Green approach, crude and ugly but effective: Duct tape or strapping tape.... (I'm just kidding)
I think the web is your best resource, but you may have to buy the whole case...unless you can get a line on the manufacturer for Advent and see if they have spare parts.
I hope this helps.
Mar 27, 2009 | Advent 4211c Notebook
I have an advent T9404. I need to open the case to add RAM. I have removed the two obvious screws that hold the side panel, but the side panel will not move. I don't want to force it. Is there another...
Remove 2 screws from right rear of case, then slide the side of the case backwards. The panel is a tight fit and may require firm pressure to remove. There is no other screw or fixing point.
Jun 07, 2008 | Computers & Internet
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
May 02, 2008 | Intel Motherboard
Open Questions:
Computers & Internet Logo
315 people viewed this question
Ekse
Alun Cox
