Question about Simplicity SE3 Computerized Sewing Machine
Does not sew, I think it is problem with the bobbin
Hello, I was embroidering a hat for my grandson when all of a sudden I had the thread ravel. I got it out ok but then the machine would not sew another stitch. I cleaned out the bobbin and I don't see any thread anywhere. Could you advise me as to what to look for?
  • Gail Gehly Aug 24, 2007
    Sorry I didn't get back sooner, family emergency. The machine seems to work fine, the needle goes up and down but it does not make stitches. I replaced the needle, put in a fresh bottom, rethreaded the machine a couple of times. It still does not make stitches. It goes for a while and the message check to see if upper thread has broken. It hasn't.
  • hammer59 Jul 01, 2008
    The section that holds the bobbin appeared frozen. I can manually move it back and forth but when the power is applied only the needle arm moves up and down. I was sewing some heavier items, is it possible I ruined a
    bearing or something?
    Thanks, hammer59pk@gmail.com
    Novelist:
    Scholar:
  • 84 Answers
Hi Gail4456...When you say "would not sew another stitch", do you mean that it is at a mechanical-stand-still? Or do you mean that the machine runs, but does not stitch? Please update/correct me if I am misunderstanding your issue. If your machine is 'frozen', remove your bobbin and needle. firmly grasp the balance wheel (handwheel on the right), and smoothly turn it clockwise until the jam is free, then use compressed air or brush or vaccuum to rid the now dislodged thread. Other possible causes for non-operation include: raised presser foot and/or un-depressed or faulty start/stop button. If your machine is not producing stitches: 1) Replace your needle, ensuring the slotted side is facing towards you. 2) Wind a fresh bobbin, and ensure that you are threading properly through the bobbin tension spring. 3) Completely remove your spool of thread, and slowly rethread your machine ensuring that you don't miss any guides, and that your thread isn't becoming wrapped around the takeup lever accidentaly. If you believe that you have a threading issue, do not retrace your thread. Instead, completely remove the spool and bobbin, and start again. I hope this corrects your issue my friend.
Posted on Aug 02, 2007
  • Maria Pierce
    Maria Pierce Jun 01, 2012
    I have the same problem and it isn't threaded incorrectly it hes to do with the bobbin hook mechanism no longer spinning so it doesn't thread the bottom thread and therefore can not do anything how can I fix this without paying $125 at the sewing center? ?????????
Why is my bobbin thread is showing while embroidering
Your tension on top can be loosened. If this causes your stitch to be too loose then tighten your bobbin tension. Just think of the top and bottom tensions as a tug of war. They must be even to get the stitch in the middle of the material.
Jul 31, 2014 | Baby Lock Sewing Machines
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
Mar 26, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
PR600 does not pick up bobbin.
needle/hook timing is off. Best to take it to authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of authorized dealers is available on the Husqvarna Viking website - http://www.husqvarnaviking.com/us
good luck.
Mar 12, 2009 | Husqvarna Designer I
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Embroidery Problem with my disney
Check your bobbin case. Thread the bobbin through your bobbin case while holding it in your left hand. Pull the thread with your right hand and feel if there is any resistance. If not, you need to adjust the tension on the bobbincase. Also check if a piece of thread or fluff did not get stuck between the tension blades on the bobbin case. If you are not sure how to adjust the tension on the bobbin case, ask your dealer to do it.
Dec 18, 2007 | Brother SE-270D Computerized Sewing...
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Simplicity SE3 Computerized Sewing Machine Logo
297 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
