Question about ScanSoft Computers & Internet
Canoscan Find a File CNQSG110 to download
Canoscan is not working
Lide 60 not working in mountain lion
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
  • If this is the first attempt to install the scanner, skip this part
  • Trash the following files/folders from these folders:
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
  • Restart your computer, then empty the trash
SECOND PART: MAKING YOUR SCANNER WORK
  • Make sure your scanner is well connected
  • Download the right driver depending on your Model. Also download the Scanner Software. Copy the filenames and search them via Google. Make sure you download the Canon files from an official Canon domain.
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
  • Open the downloaded driver file (lide35osx7721en.dmg or lide60osx11131en.dmg)
  • and Double-click the ScanGear file, install and restart when prompted
  • Open the downloaded VueScan file (vuex3292.dmg) and drag the VueScan application to the Mac Applications folder
  • Open the VueScan application. The scanner should be recognized automatically.
(Alternatively try and install CanoScan Toolbox 4 or 5)
Nov 04, 2012 | Canon Office Equipment & Supplies
Install canoscan LIDE 500F
Hello you can download the driver here:
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_500f?selectedName=DriversAndSoftware
Its free and remember to select
your current operating system 32 or 64 bit.
Good luck
Oct 12, 2012 | Canon CanoScan LiDE 500F Flatbed Scanner
Hi. i have a canoscan FB 630P. Can i use this in windows 7 ? If yes then how and where will i find the driver software..?
Hello mshouvo,
it seems that the "Canoscan is only compatible with,
{up to Windows XP}.
The Drivers that you need can be found at the "Website"
I placed a link to, below!
If you have Windows 7 as your "Operating System;"
than you can use the Canoscan with the "Drivers in [Compatibility Mode].
Once you "download the 'Drivers.'
Disconnect the Canoscan; {Safely!}.
Install the Drivers.
Restart the computer.
Connect the Canoscan; the computer should "automatically"
'detect' the Canoscan, and "update the Drivers.
Next, {right click} on the Canoscan, to open the "Properties" window.
There will be "buttons," one them should be a [Compatibilty Mode] button!
"Use the program in "Windows XP" mode, and click on the 'Apply and OK buttons."
"Best Regards"
Click below for Drivers: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_fb_630p#DriversAndSoftware
Jul 13, 2011 | Computers & Internet
Problem with the Canon CanoScan LiDE 25 Flatbed Scanner Installation CD lost My scanner model is canoscan lide25 instalation software free download F910111
HI there,
Please go to the link below, choose your operating system, and you'll be directed to the download page for your software. Download it by saving it to your Desktop. Double-click on the saved file and your installation will proceed.
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide25#DriversAndSoftware
Regards,
Selk
Apr 05, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I can't get my Canoscan n676u to work on my laptop running Vista. Any suggestions?
You can download the driver of CanonScan N676U for Windows Vista operating system and install it.
Please click here which you can download the driver. In the web page, under the headline “Drivers/Software Selection” select your OS (Operating System) as “Windows Vista”. Then, find the “Drivers” headline below and click on the file name “lide20lide30n670un676un1240uvst7031a_xpen.exe” to download. After downloading please install the drive running the downloaded exe file.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | Canon CanoScan N676U Flatbed Scanner
Can't get drivers for CanoScan N650U scanner for Vista 64 bit. Anyone have a work-around?
This works for 32-bit, maybe try the same for 64 and see if it works?
1) Download the drivers for XP from Canon's website
2) Install the drivers.
3) They will install to C:/Temp/CanoScanCSUv571a, go there
4) There is a compressed file called: CanoScanCSUv571a.exe in the foler
5) Use 7-zip to uncompress the folder
6) Plug in your scanner
7) Go to your device manager under the Control Panel
8) Go to Imaging Devices and select your scanner
9) Right click to update driver information
10) Select browse my computer for driver software
11) Type in: C:\Temp\CanoScanCSUv571a
12) Click next and your scanner will work.
Jul 05, 2009 | Canon CanoScan N650U Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
Driver download
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Canon Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find thefile,doubleclick on the file, if you get introubles,then follow the instructions below to reset and reinstall:
  • Unplug USB.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some device does not work on Vista.
Oct 12, 2008 | Canon CanoScan D646U Flatbed Scanner
Trying to make a copy- worked last week?
This is most likely only happening when attempting to scan through the CanoScan Toolbox. You can scan directly through ArcSoft PhotoStudio which came with the scanner. However, the error through Toolbox is likely caused by some limitation or restriction in the computer, possibly permissions of some sort. You may try deleting temp files from the Temp folder on the hard drive.
Jul 15, 2008 | Canon CanoScan 4400F Flatbed Scanner
Computers & Internet Logo
585 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
