Question about Frigidaire ATF6000ES Front Load Washer
Belt on Frigidaire front loader
The belt on my 1 year old washer broke. I bought the new one but is there a reason why the old one broke (e.g. do they go out of alignment)? Also is there a desired way to put the new one on?
  • 640 Answers
Bingo they run crooked sometimes,,and sometimes there just defective,,if you have the back of already ,,just slip it over motor pully,,,than the tub pully hold wiht 1 hand and turn the big pull with the other...onthejob
Posted on Feb 02, 2009
Front loader hums instead of starting
Try to get ahold of a qualified service technician that specializes in washing machines and dryers.
My guess is it could either be if its belt driven the belt has broke and the drive motor is turning freely or the drive motor is possibly burnt out or in need of replacement.
Its not much but I hope it helps
Sep 27, 2013 | Frigidaire Affinity ATF7000ES Front Load...
My 4 year 0old front loader is no longer spinning dry the laundry. Was bought from Charllotte Appliances, Rochester NY
Hello & Welcome to FixYa
If you have already checked the drain pump filter (located inside the bottom front panel) and the drain hose for any blockages, then the problem is with the belt going bad, its either worn out or loose. To check what is bad you have to take it apart and then check the belt, if bad replace it. Please get back to me if you have any other questions.
Kevin
Jan 18, 2011 | Frigidaire ATF6000ES Front Load Washer
How to replace the belt that it broke
To replace a belt on a Frigidaire front loader, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps let me know. I hope this information is helpful.
Nov 28, 2009 | Frigidaire FWS1339A Top Load Washer
Plastic Mountings Let Loose - Hole in back of washer
you can fix it buthte cost would outwieghthe cost of new machine,all front loaders not exclusulve frigidaire have simillar issues, if no the tub cracking the rear bearing goes bad
Dec 03, 2008 | Washing Machines
Front Load not spinning
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Belt keeps coming off
it could be the drum bearings
Dec 20, 2007 | Indesit W 123 Front Load Washer
Washer Stopped Spinning
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
Dec 17, 2007 | Frigidaire GLTF2940ES Front Load Washer
How to replace motor belt on front load washer
I'm not familiar with the particular model, but most of those front loaders there is a trick to getting the belt on. You put the belt auround the motor pulley first then the left side of the larger pulley. Put it on as far as you can get it to go, then hold it in place while you slowly rotate the big pulley clockwise. If you do it right it should "walk" the belt up ont the larger pulley and the tension should be about right assuming you havent moved any idler pullies or the motor. Good Luck!
Oct 06, 2006 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire ATF6000ES Front Load Washer Logo
101 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
