Question about NAD C541 CD Player
Selective playing of DVD's on Sharp DVD Recorder
I have had my SHARP DV-RW250H VCR/DVD Recorder for about 15 months. It now refuses to play most (not all) DVD Video commercial discs [movies], whilst continuing to recognise and play my own burned discs. The Recorder is set Region 2 and all discs are Region 2. An error code shows 'Incorrect Disc C104. Of course the manual states this means the disc is incompatible. However as gives this message to the vast majority of discs it has played before, as well as newly bought, this clearly is nonsense. The discs play on other players and on my PC, so what has changed to make the Sharp machine to act in this way with original DVD discs?
  • Bob Spiers Aug 01, 2007
    Thank you and will try the lens clean solution. One thing I should have made clear is that although, yes, it does read recorded discs it has made itself, it also reads discs burned on my PC. When an original (commercial)DVD is inserted, it shows 'reading', several whirrs, then nothing until a final Incorrect Disc C104. So any disc in my collection that has been burned, new or old, is likely to play. But bought DVD's -again new or old - do not.
    President:
  • 1,114 Answers
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Posted on Aug 01, 2007
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Does my Sharp DV-RW34OU dvd recorder+vcr have microphone capability? If so can I purchase a compatible microphone online?
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Jul 03, 2010 | Sharp DV-RW340U DVD Recorder/VCR
I want to dub a vhs tape to dvd-rw but have lost my product manual- I have had a go once already and the dvd is set to the correct channel to record what is playing on the vcr but there is no data on the...
connect the red/white/yellow from the input on the dvd to the red/white/yellow on the vcr sellect av1 on the dvd recorder and you should be right and as a bit of help here is the manuel to your dvd recorder
it is written in pdf so if it does not open you will have to download adobe reader its free go to adobe.com
http://www.cyberscholar.com/sharp/resources/dvd_man_DVRW350U.pdf
May 15, 2010 | Sharp DV-RW340U DVD Recorder/VCR
I need a manual Sharp DVRW550U DVD Recorder / VCR Combo.. when i record into the dvd it say that i cannot recorde into this dvd i already try so many diferent one and it say the same thing.. when i think...
I have three possibilities for you. One obvious answer would be that you are trying to record onto either a CD-R rather than a DVD-R, but I'm assuming that's not your problem. The second would be that you are trying to record onto a dvd that your recorder doesn't support (i.e. DVD-RW and your recorder only supports DVD-R). The final possibility is that the disc is a "dud." I have had this problem before and just had to try another disc. Good luck and let me know how it turns out, will you? Der Strom
Apr 02, 2010 | Sharp DV-RW340U DVD Recorder/VCR
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Copying vidoe to dvd
Hi, if you still have the problem of unable to copy from video to dvd,then just follow these instructions, on the Remote, (when you have both the video tape that you wish to copy in the machine and the blank disc also in the machine ) Press the DUBBING Button(This is 2 buttons along from the Record button),almost immediately a message will pop up asking if you wish to copy VCR to DVD.
Hopefully this is of help to you. Regards. Gary
Dec 02, 2008 | Sharp DVRW250 DVD Players
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Region unlocking for a Sharp DV-NC80
I would like to play Area 1 DVDs on our Sharp DV-SL 1200 DVD player - please help us unlock it - Many Thanks
Apr 10, 2008 | Sharp DV-NC80 DVD Player/VCR
NAD C541 CD Player Logo
310 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
