Question about Vizio GV42L 42 in. LCD Television
No sound If switch to regular TV, then I have sound, but when switch back to cable there is no sound. Was working good Friday night, Saturday when turned tv on, had picture but no sound. Please help
    Problem Solver:
  • 10 Answers
Yep this seems to be a common problem of the main board acting up due to faulty parts that get old prematurely. The source of this problem may be traced (?) to the power-supply regulation spiking caps in different sections of the main board or faulty discount-caps failing where ever they hapen to be used in the schematic.
The jury is still out...
Posted on Feb 16, 2009
Sony KV32XBR400 Video Won't Turn
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Oct 14, 2008 | Televison & Video
Sony HHTS360 HDMI OUT does not send signal to my Sony HDTV. It worked fine Friday night but when I turned it on Saturday morning the tv message read "no signal" and I had no picture or sound.
Make sure your connections are good unplug and plug in again. They are not real hard to pull out. This is a bluray player correct? If that doesn't work, do you have any other cables you can use to test your blueray player? Depending on what you have for output,input, you can use "composite"(red, whute, green"), component(blue, green, red), to check output of bluray. You will not get audio using component cables. You will have to use red and white composite or digital audio. Let me know what happens at "add a comment"
Dave
Mar 27, 2011 | Sony Audio Players & Recorders
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Hitachi pd7200 42" plasma
unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
mark
Dec 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Tv wont turn on
3 blinks corresponds to convergence ICs
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 11, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Repair issues
call the repair shop back to let them know that there is a possible fault and have it notated they must offer some kind of warranty on their repairs/
Sep 10, 2006 | RCA HD52W59 HDTV Projection Television
Vizio GV42L 42 in. LCD Television Logo
49 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
