Question about Minolta DiALTA Di520 Laser Printer
Copier proplem I have Minolta DI 620 with code c 1462 on the display. how to solve it?
1. Reset the malfunction (i.e., turn OFF and ON the Power Switch).
or 2. If the same malfunction is still detected, check the EDH harness and, if it is okay,
change PWB-IB.
Posted on Jul 15, 2009
How do i solve 1462 code minolta 620 photo
Image reader fault, the small device under the big glass that see the original document is bad. Its called CCD (Charged Couple Device) Located in the middle of the its what the mirrors move toward as the original is copied, raise the document feeder and hit start. as the bright light move towards that device replace it if you can find one its a very old machine, try third party, MAKE SURE you remove the proper bolts if they are red do not unscrew them!!!!!!
Feb 28, 2015 | Minolta Office Equipment & Supplies
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
I have a Dialta Di-620 copier with an error code C-0540
i have a problem di620 code error c0540 please solve this thanks alote
Aug 23, 2011 | Minolta DiALTA Di620 All-In-One Laser...
I have Minolta DI 470 copier , and when i print from my computer it displays " error printer 1808" , i can't found any solution till now. Can anyone help me to solve this issue.
An 18xx code that can't be reset is caused by a problem with the image processing board. Most likely it will have to be replaced.
I'd call for service on this one.
Mar 06, 2011 | Konica Minolta Minolta DI1811P Digital...
Sir i want to know about the operating keys by which experts find & solve Problems of Digital copier Di 620 or 520.
To give out all the technicians codes and uses can result in your copier failing to work correctly(or at all) again unless you are aware of each adjustment and what it does.
Oct 11, 2009 | Minolta Office Equipment & Supplies
Scan with minolta Di 620 . Is there a way?
Go to the website and search for the "TWAIN" driver for the relevant model
follow this link :
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Nov 20, 2008 | Minolta DiALTA Di520 Laser Printer
Code C-0500 on Di 620
Try opening the front door with the copier on, on the right hand side you will see a small cover held on by 1 screw, remove this and press the reset button then close the door. If the error is still present it will return.
May 18, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Problem in networking minolta di 520/620
do you have the optional print controller installed? if not you would need to buy one.
Jan 26, 2008 | Minolta DiALTA Di520 Laser Printer
258 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
