Question about Dell E173FPs 17" TFT LCD Flat Panel Monitor
Power connection of sound systen
Dell E173FPs. I bought this monitor as used connected with the AS500 sound system. However, I do not manage to find any place where I could plug in the power supply cable of the sounds system into the monitor. Should there be a power output for this purpose in this monitor model as well?
  • robert718 Feb 01, 2009
    I fully understand and I have connected the audio cable to the CPU, however the prolem is that the AS500 seems to need an own power supply, however I havent located any input in the monitor that could support the function i.e. provide electricity to the audio unit. The cable in the audio unít is only 5-6 inches with a plug that looks like somehting that could be connected to the monitor, however I can not find any place where to plug it in.
    Guru:
  • Dell Master
  • 829 Answers
Hi ,
Please note it does not come with a Sound System in built you in turn have to connect to the CPU.
Posted on Feb 01, 2009
Does anyone have a schematic for a Samsung 35135A power board in a Dell E173FPs flat screen monitor?
You can probably get one from eBay or try Dell's website. You can download user manuals and tech manuals. at dell.com
Apr 09, 2012 | Computers & Internet
When I power the Dell AS500 Monitor on, it flashes for a brief second then goes blank but the power switch keeps blinking. The monitor does not function but I do get sound
Check and see if you see a faint image in the back. If you see it, then the backlight has failed. If you cannot see any image, then the power supply on the monitor has failed. You should contact Dell to see if the monitor is covered under warranty in either case as you have a faulty monitor.
Jul 06, 2011 | Dell Computers & Internet
How do i use my sound bar without an actual computer tower?
the sound bar AS500 gets it's power from the LCD it is attached to, if you are using a portable, connected to an LCD then you can still use it.
If it is an AS500PA then it has it's on AC power adapter, then you can connect it to any computer.
Oct 09, 2010 | Dell AS500 Sound Bar Computer Speakers
How can I use the AS500 DELL sound bar with my DELL E1910 monitor. there is no power to plug into?
///////http://www.stuartconnections.com/ebay/Peripherals/LCDs/Dell_E193FP/UsersGuide/English/SOUNDBAR.HTM/////// Hope this helps (Link is without //////)
Aug 10, 2010 | Dell AS500 Sound Bar Computer Speakers
Dell AS500 speaker Bar substitute
Hello there, of course you can use the same exact sound bar and connect it at the bottom part of the monitor or basically replace it with any other desktop speakers- those that you can just put on tope of yout table. For more info on Dell and other branded speakers, you can visit their website here:
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6587&cs=19&l=en&s=dhs
Regards,
Melgasbal
Feb 22, 2010 | Dell Computers & Internet
No sound from as500 speakers
Hi there. If the sound bar is plugged into the monitor you also have to make sure that you have the cable from the bar plugged into the audio jack on the pc which is the pale green port. Hope this helps Mark
Aug 22, 2009 | Dell AS500 Sound Bar Computer Speakers
Dell E173FPs LCD screen (4 years old) is blank, power button is blinking green. I have read numerous articles about the same problem on similar models (E173FPc?) caused by poor solder connections at...
Replacing transistors would be the last thing in that troubleshooting. First, check all electrolytic capacitors if there are any of them "bubbled", replace those. Next, if there is the fuse used for supplying DC voltage to the inverter area, take it off and check if LED will still blink as before. If there's no such fuse, you can cut the trace, supplying DC voltage to the inverter, another words, you need to unload inverter from power supply and check LED behavior then, if it will stay steady, then next steps will be to troubleshoot the inverter, otherwise, using ohmmeter ring all capacitors and diodes in the power supply part, especially connected to PWM chip at primary side of pulse transformer. By the way, what kind of chip is there?
Apr 05, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My AS 500 Sound Bar speakers are crakeling (PArt # 4y463)
Usually, the crackling indicates a connection that's not making a good connection. you can try twisting the plug where it connects to your computer and see if you can get it to make a better connect. Also, you may try cleaning the plug itself. When cleaning contacts with any sort of household alcohol, be aware that it can leave a residue so you'll need to use a clean/dry tissue to dry the plug and remove any residue. -hope that helps.
Nov 30, 2008 | Dell AS500 Sound Bar Computer Speakers
Where do I plug the speaker in?
Please be more specific - Usually on the back of any computer you have 3 outlets at your sound card:
one is for "mic" (pink)
one is for "speaker" (green)
one is for "line in" (blue)
Oct 07, 2008 | Dell AS500 Sound Bar Computer Speakers
Dell E173FPs 17" TFT LCD Flat Panel Monitor Logo
122 people viewed this question
Alun Cox
