Question about Intel Motherboard
I have a D945GPM
I need to get my hands on a manual because my so n pulled the wires out of the 945 cabinet and i need the manual to place the wires were they belong.
I thank you in advance.
Harry
    Problem Solver:
  • 13 Answers
Follow the below link
http://download.intel.com/support/motherboards/desktop/d945gpm/sb/d2184202_en.pdf
Posted on Feb 01, 2009
My fridge needs a new combination thermostat which has a capillary temperature probe attached. How do I fish the new probe into the fridge cabinet?
Kevin, put a long strong string or long thin wire on old probe before you pull it out. Then you can attach onto new and pull/guide new one into place. If you have unfortunately pulled old one out already, feed a firmer wire through hole in fridge till you see it out the back, tape probe onto wire and fish it back.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jul 06, 2016 | Refrigerators
My audio system is not working and i have no driver of it my mother board number is D945GPM
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows
operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Apr 11, 2011 | Intel D945GPM Motherboard
How do you install a lid switch
Hello there
First you will need to remove the two long screws that run down into the cabinet on both sides of the machine, followed by two smaller screws on the top corners of the control panel.
Now Slide the whole panel towards the front of the cabinet about 1/4" and rotate it back over the back panel. The wire assembly will hold it from falling to the floor (watch the tubing that runs on the top edge). Located the plug that leads to the lid switch and pull up on the tab and wiggle it out. Push the tabs on the side of the connector on the cabinet and push it through (watch the metal edges). You will see two metal clips on the left & right top of the cabinet. Put a screwdriver in the notch on the front side and pop them off. Take note on how they are set in the two sides Place hands on both sides of the cabinet and pull towards you, it will rotate over and you can access the lid switch. Remove the two screws from the inside of the lid. Slide the wires & plastic casing off the two small clips on the rim & replace with the new switch. Be careful not to tighten too much cause you'll split the plastic mounting. Reverse the process and your back in business. Hope this helps
Best regards mike
Jan 23, 2011 | Whirlpool GSQ9364H
My kenmore 70 series washer quit agitating and spinning today. what could it be?
i think you will find the belt at the bottom has broken or come of here are the directions to replaced / re fit it
best of luck
merry christmas
  • Unplug the power cord of the Kenmore 70 series washer from the electrical outlet before attempting to replace the drive belt. Remove the end caps from the control console by pushing in on the center of the caps with your thumbs and pulling the caps forward.
  • 2 Unfasten the screws on the front of the control console with a screwdriver and set the screws aside. Flip the control console back so it is resting against the rear hinges.
  • 3 Locate the two-pronged electrical plug on the top of the washer near the back and unfasten it by pulling the plug straight up by hand. Remove the metal clips on the top of the washer, prying them up with a screwdriver and setting them out of the way.
  • 4 Lift the washer cabinet off the base and set it aside. Locate the motor at the base of the cabinet near the front and unhook the springs from the motor carriage with a pair of pliers.
  • 5 Unbolt the motor from the motor carriage, using a socket wrench to unfasten the bolts. Unplug the electrical wiring harness from the motor by hand.
  • 6 Lift the motor off the motor carriage and take the drive belt off the motor and transmission pulleys, discarding the belt. Place the new drive belt around the transmission and motor pulleys.
  • 7 Plug the electrical wiring harness into the motor by hand and secure the motor to the motor carriage with the bolts. Attach the springs to the motor carriage by hand.
  • 8 Place the washer cabinet back over the base and secure it with the metal clips on the top lid. Connect the two-pronged electrical plug to the top lid of the washer by hand.
  • 9 Flip the control console back down over the washer lid and secure the console with screws in the front. Place the caps back over the ends of the control console by hand.
  • 10 Plug the Kenmore 70 series washer into the electricity supply and test wash.
  • have fun
    Dec 08, 2010 | Kenmore Washing Machines
    I need to repair my washing machine Model KAWE577BWH1
    To remove the cabinet safely, the washing machine should be turned off and unplugged. Next take out the control panel by removing the screws. Also take out the spring clips which are situated in the corners and after doing that remove the harness that is connected to the lid switch wiring. Pull the lid and also keep a hand on the cabinet opening that shows itself when you open the lid. Furthermore adjust the cabinets position and then pull the lid and the cabinet opening. It should be removed now.
    Feb 18, 2009 | KitchenAid KAWS850LE Top Load Washer
    D945GPM
    You can download it from here: Click Here
    Feb 01, 2009 | Intel D945GPM Motherboard
    Manual for d945gpm
    you can get all kind of resources regarding D945GPM at
    Now direct link to ur Manual(Product Guide) a PDF file is
    Feb 01, 2009 | Intel Motherboard
    Cant get the back panel off the washing machine
    If it is a top loading washer the cabinet itself is actually removed from the back panel and base frame.
    1. Remove two trim caps on either side of the control panel, they are just plastic, and clip in place, either remove by hand, or if they don't come right away you can pop them off with a flat blade screwdriver.
    2. Remove two screws (now visible with trim removal) that secure the panel to the cabinet.
    3. Panel should now be able to pull up and out, flip it back on it's hinges.
    4. Disconnect the wire harness from the lid switch connector, this should be the only place (on most models) where wires connect from the control panel to the cabinet top.
    5. Remove the two gold clips that secure the cabinet to the rear panel of washer, they snap into the cabinet, and should pop out easily with a flat screwdriver, this can be difficult to figure out which way to go with the screwdriver, the best I can describe it would be to slide the blade of the screwdriver into the front of the clip (about 2 inches below the cabinet top) and then press the screwdriver back over the top of the clip for leverage. It should pop right out.
    6. With the clips removed, you should now be able to simply tip the cabinet towards yourself and pull it right off of the frame. The washers "guts" should all be accessible now.
    Hope that helps.
    Sep 14, 2008 | Washing Machines
    Intel Motherboard Logo
    35 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
