Question about Nokia N73 Cellular Phone
Back camera not working even neither with slider nor with direct camera options, plz help
N73 back camera not work
Posted on Jan 03, 2011
This is back slider problem!not camera malfunction! change your phone casing to a new one! and try again!
*if your camera is malfuction,it always shows HARDWARE FAILURE,RESTART YOU CAMERA!
so don`t be scared if not displays somthing like this!
(oops sry for ma bad english,coz im 4rm sri lanka)
Posted on Mar 28, 2011
  • abdulkhadarm Apr 11, 2011
    my n73 mobile both front and back camera not working please tell me solution
When i turn on my camera it says write protection and i cant take any photos
I looked at the specs for your Olympus SP800UZ Digital Camera, it must be quite new because they were only announced on 2nd Feb last year. Nice camera :-) Your camera takes the regular SD or SDHC cards, so this write-up that I've posted before certainly applies in your case. I hope that it covers all the possibilities for you, comment back if you have any extra questions, for example if you need to find the system reset in your particular menu.
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Mar 22, 2011 | Olympus SP800UZ Digital Camera
My camera is reading card locled?
Diagnosis.
Feb 15, 2011 | Canon PowerShot A530 Digital Camera
What dos it mean when my TL205 camera says "card
Diagnosis.
Feb 03, 2011 | Samsung DualView TL205 Digital Camera
How to remove write protection from my camera dsc h55's memory card
Diagnosis.
Jan 24, 2011 | Sony DSC-H55 Digital Camera
Hello when I turn on my camera says "the card is
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position, which you say you already did. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
Jan 23, 2011 | Casio EXILIM 8.1-Megapixel Digital Camera...
I have an Olympus digital camera. I was taken pictures today and the screen came up Write Protect. How do I fix this? It also will not let me delete older pictures. I never had any problems with this...
If the camera is giving you this error, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty.
The slider is really tiny, so I suspect that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Obviously the first thing to do is to check that the slider is NOT in the lock position. After that I would try a different card (of a different brand) to see if small differences in thickness are the problem. Does a better brand of card work?
As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I would only do this if no cards work properly (implying that it's the camera at fault). If some cards work and some don't, it would be better to simply limit yourself to the good cards, as there's a risk that the tape will come off in the slot and cause even more problems.
Jan 21, 2011 | Olympus Camedia D-395 Digital Camera
File error and does not upload
Sounds like your card is locked. There's a tiny slider on one side of the card with 2 small symbols (an open and a closed pad lock). Move the slider to the open pad lock. If the slider is set to open, then you might have locked the images in camera. If that's the case go to the review menu of your camera and scroll through the options to option 'protect' and change the setting there to 'unprotect all'
One of these 2 should solve your problem. Hope that helps
Jul 26, 2010 | Polaroid i835 Digital Camera
My sony cybershot DSC-T100 digital camera as fall down from my hands now it is in working position but it is vibrating like mobile phone when i am opening the shutter. So plz any one help how to solve the...
Please reset the Camera and check if that helps.
To reset the Camera, select the INITIALIZE Option from the MAIN SETTINGS 1 Menu of the Camera to OK.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON the Camera and check if that helps.
If the issue still persists even after power resetting the Camera, unfortunately the Camera requires service.
Thank You!
Apr 09, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
My N73 back camera auto opens at anytime, closes and reopens again without using the slide
if you have tat problem then there is problem in your back panel if you change it your problem wil be solved
Feb 03, 2010 | Nokia N73 Cellular Phone
Camera
the front camera is used for video calling only.
Oct 23, 2008 | Nokia 6500 Slide Cellular Phone
Nokia N73 Cellular Phone Logo
756 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
