Question about Garmin Nuvi 680 GPS Receiver
Defective Internal speaker on the Nuvi 680
I was listening to an audio book that was so boring. I fast forwarded several times to skip the boring parts but after fast forwarding back and forth for about the 7 or 8 times the audio stopped working. It works for a second or two if I tap the device with my finger. The audio works perfectly well with my headphone.
  • peter7861 Feb 01, 2009
    Its past the warranty
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your post tapping the device with your finger makes it work is significant. This tells us that the device is basically functional and that the issue is limited to the internal speaker. This then could either be a cold solder of the speaker wires or the voice coil of the speaker is intermittently connected. Either way, the unit has to be opened and looked into. Offhand, I am more inclined to a loose connection of the voice coil but would not of course discount the cold solder.
The challenge then would be opening the unit.
Good luck and thank you for using FixYa.
Posted on Feb 01, 2009
    President:
  • 2,559 Answers
The speaker voice coil has been damaged due to the frequencies produced during the fast forward and rewind action,Since there are no tape heads or any moving parts in the unit,the speaker is the only thing that can be damaged by the sound frequencies in question.taping on it only allows the voice coil to temporarily realign.
  • Randy Hough
    Randy Hough Feb 01, 2009
    This can only be repaired by replacing the speaker.
  • 744 Answers
Hi... The problem is due to as u mentioned earlier due to repeated fast forwarding of songs.. dont try to tap the device again as it may lead to big problem...the tape head of ur device would have got damaged... so replacing that would solve ur problem
    Guru:
  • 829 Answers
Hi Is it a New Purchase if yes Any item that is found to be defective within the first 30 days after you receive the item may be replaced.Check out with the vendor.
  • 679 Answers
Please tell me in which format you copy the music files to your gps receiver.
  • 1 more comment
  • rockfixya
    rockfixya Feb 01, 2009
    MP3 file format is best file format for your gps device,
    Thanks
  • rockfixya
    or
    there are many files runing in memory so u have problem while fast farwading, you need to close all backgraund running files (operations).
  • rockfixya
    reset your GPS.
    go to the following link for the trick>>
    http://gpsinformation.info/nuvi/660/660....
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Sep 24, 2010 | Garmin Nuvi 610 GPS Receiver
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
How can i fast forward on an audio book
there's no function for this on mp3 players.if you know you're going to want to do this frequently when you're reading the book it would be better to download it in chapters and then you could at least jump from one chapter to another without listening to the whole thing each time.You could record chapters or the whole thing onto Audacity ( A free sound recording program) and break it up into smaller sections.This is a lot of messing about and you'd probably be better off trying to find the book as an ebook and just search out the relevant bit that you'd missed and read it instead. I think it would be a great step forward if mp3 players were able to do this.The only equipment I know of that can do this(other than a media player on a pc) is on some digital radios where you can pause and do a rewind to the bit you want but this is usually only over a short period (5 mins for example on the Roberts digital radio.
Sep 10, 2009 | Audio Players & Recorders
Tip
No Sound Issue on the Garmin Nuvi Series
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin nuvi 350 GPS Receiver
No sound
Aug 13, 2009 | Garmin Nuvi 660 GPS Receiver
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Fast Forward
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 31, 2008 | Creative Labs Zen Touch MP3 Player
Audio problems
Steps:
1. Make sure battery is charged. Go to Step #2.
2. Press reset button and try it again. If still bad, go to step #3.
3. Try using headphones.
By using the headphones, you are bypassing the internal speakers, which might have failed. If the sound is still missing, the mostly like problem is a defective audio output stage on the motherboard.
Since this unit uses surface mount technology it will have to be sent back to the manufacturer for repair.
If the sound works with the headphones, the speakers have failed. I have seen several postings of speakers failing in the Nuvi 350.
In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Jan 14, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 680 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
