Squeeking noise from unit when u switch set on but no picture?
When turn on phillips 55pp8620 an audible squeeking noise coming from right hand side of unit but has no picture ?
  • 8,617 Answers
Sounds like the HV generator will need to be replaced. Can you tell if the sqeaking is coming from this component without touching it?squeeking noise from unit when u switch set on but - 33c0a28.jpg
Posted on Feb 01, 2009
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
Squeeks and creeks from the front right wheel on my honda civic
you could have 2 problems. steering leak and poss a bearing. jack up the car and spin the right front wheel, makes noise there is a problem. if the noise only happens when you turn, with tire off turn the wheel and watch.
Mar 06, 2010 | 1997 Honda Civic
No picture on my sony kds-50a3000 red blinking light at lamp spot
If by noise, you mean a loud, audible pop--then it's your lamp that imploded.
You should be able to just pop off the cover on the side (right side if you are facing the front of the set), remove the internal lamp cover (if present) and yank (I mean, gently pull) out your lamp.
Look for all the bright particles of glass inside your newly imploded lamp. Replace with a Sony original, as these sets can chew through generic lamps very fast.
Now, if by noise you mean something else, please elaborate.
Jul 30, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Heard a clicking noise right side interior now won't start
just under the pressure of the car or tune it up its normal for civic
Dec 28, 2008 | 1997 Honda Civic
Squaky nose in maytag gas dryer model mdg3000aww
Here we go. First unplug the unit. Remove the front panel by removing the 4 phillips screws just inside the door (on the hinges and just opposite). Next remove the greenish/ brown 5/16 screws that hold the front panel in. There are wires still connected (door switch and moisture sensor) but if you swing it to the side, you can leave them connected and still procede. Next, you have to reach underneath (very difficult to see this so you will have to do it by feel) There is a belt that wraps around the drum. On the underneath side of the drum as you follow the belt it wraps around the motor pulley (small wheel) and the tensioner pulley (bigger wheel just to the right). Now with one hand, move the larger pulley towards the msaller one. This will give you slack and you can take the belt off both pulleys. Now pull the drum forward. There you have the inner workings left. Now, there are 3 wheels. 2 black and 1 white. Your squeeking noise will be coming from the one that doesn't turn freely. You can get the replacement wheel from your local appliance parts store or on line from the manufatrues web site. However, if you do have to wait for the part, take the wheel off the shaft and wipe off the inside race of the wheel and the shaft for temporarily relife and useage.
Jun 18, 2008 | Maytag Dryers
Maytag mdg3000aww
relife and useage.
Jun 18, 2008 | Dryers
Colour misalignment and focus
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
May 21, 2008 | Philips 60PP9202 60" Rear Projection...
I have a 42 inch phillips model 42pfl7662d 1080dp lcd tv. today it started making crackling noises at the rear right hand side, then it automatically switches itself off, and then on again after a minute...
sound s like the HV generator (flyback) This is repairable with a new flyback if that is indeed whats happening. Take the back off and dont touch anything but try powering up the set and see if the noise is coming from a part that looks like this with 4533b6a8.jpg big red wire coming from
Mar 30, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
