Question about GE GDS18LBP Bottom Freezer Refrigerator
Refrigerator is not cold
The refrigerator is not working; I do not hear any compressor operation and changing the thermostat does not help.
  • jpimentel Feb 06, 2009
    have the same problem, my fan,watter dispencer, & lights work! Please help. Thanks
  • 306 Answers
Pull the unit away from the wall and take off the card board cover that hides the compressor. Now look on the compressor and do you see the little white or tan block attached to the compressor? That is a PTC relay I have a hunch it is bad. Cost about 30 dollars to replace you can get one at a appliance repair parts house.
Take the relay off the compressor and if it rattles it is bad.
Posted on Feb 01, 2009
My Westinghouse Rp241T fridge is not getting cold. I can hear the motor running but it isn't cold. The fridge isn't very old and I suspect the thermostat?? Where is it located or am I off the...
Hi, Sounds like there was/is a leak in the refrigerant system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Fridge and freezer warm. condenser fan, evaporator fan and compressor running, cleaned condenser coils, new defrost heater and defrost thermostat. Still no cold air?
heatman101
Aug 27, 2011 | Refrigerators
Fridge/freeger does not get cold,i changed thermostat it is still the same.what i can do to solve it.thank you,r.s.dhanjal
heatman101
Apr 17, 2011 | Refrigerators
Compressor not coming on hear silonid or contacts
The capacitor is bad....
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Mar 08, 2011 | Magic Chef CTF2125 Top Freezer...
Refrigerator getting to cold , thermostats at mid-range. Technician said thermostats faulty , i don't share that view .Before this refrigerator condenser was changed due to a leak & corrosion on it,...
The thermostat is the only thing that turns the compressor on and off with temperature.
Turn the thermostat to its lowest setting and see if the compressor turns off.
If not,the thermostat is bad.
Feb 21, 2011 | Refrigerators
Top freezer - not freezing - thermostat dial for cooler - no change when moved to colder. do not hear a fan or compressor turn on - of course lower not cooling either. (frigidare) model #...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
Refrigerator
heatman101
Dec 15, 2010 | Frigidaire Refrigerators
The motor is running, but the temperature on the freezer and the refrigerator go up. Worked a couple times by unplugging and replugging. Now, cannot change the temperatures on the digital thermostat.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 16, 2010 | Refrigerators
Food in my refrigerator freezes I have a top freezer maytag
There are 2 things to check - Your cold control dial - to rule out a thermostat problem lower it to 1 gradually and slowly until you hear a click and it shuts off - If it does not shut off, and only shuts off if you set it to the OFF position, then you have a thermostat problem and your compressor is continually running, freezing things in your refrigerator. If lowering your dial you hear a click and compressor shuts off, then the solution is to lower your dial, you have it set too cold - There is a thermostat in your refrigerator that should shut things off when it is cool enough it's either not working properly or your dial is set too cold.
Sep 05, 2009 | Refrigerators
Refrigerator not getting cold
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermister is not registering the correct temperature causing the fan not to turn on.
Jul 14, 2009 | Maytag Refrigerators
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
GE GDS18LBP Bottom Freezer Refrigerator Logo
191 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
