Question about Hanns.G Corporation HU-196DP LCD Monitor
Monitor Samsung914v will not awake from sleep mode using Vista HP
Computer goes into sleep mode, monitor shuts down but will not awake using command key. Can't find solution on Samsung website.
  • 1 more comment
  • jonc190 Feb 01, 2009
    Using Vista home premium on HP Pavillion s3700f with Nvidia 6150 card. Not using wireless mouse although I have USB connector with serial adapter in use.
    Thanks for the suggestions.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Two questions. Are you using a wirless mouse and or you using Windows Vista.
  • 741 Answers
The only thing I could find is that it's a bug in Windows Vista operating system and that make sure your Service Pack and all hotfixes are updated.\
Try this and see if it will temporarly work for you until a permanent fix comes in. before you log off, do a Crtl-alt-delete. Then click on processes. See if you can find your video card listed in the processes and right click it and then stop it. After you've stopped your graphics card then go ahead and put in in sleep mode see if it will come up. Here's the website where I found about the bug, if you want to peruse the Microsoft Knowlege base you may find something else. http://support.microsoft.com/kb/937500
If you have any questions let me know. Please rate this with 3 stars before logging out. Thanks and let me know if you have any other questions.
Posted on Feb 01, 2009
    Guru:
  • Hanns.G Corp... Master
  • 829 Answers
Pease follow the below steps
Right-click on Desktop Screen- Select properties- Click on Screen Saver tab- Click on Power button- Change the power scheme option to "Home/Office Desk"- Click on OK to save and exit the window. This should resolve the issue and hope it resolves.
HI HAVE A NEW AOC COMPUTER MONITOR FROM AOC. IT SHUTS DOWN EVERY TIME I LEAVE IT AND I WOULD LIKE FOR IT TO REMAIN ON ALL DAY LONG AND I WILL SHUT IT DOWN AT NIGHT MANUALLY; HOW CAN I DO THIS. ...
go in to monitor in the control panel and set the sleep mode time mode
probably better if you go into bios setting and click on computer start from any key movement
that way the monitor and computer go into sleep mode and that saves money on power and you only have to move the mouse or press a key and 10 seconds later the screen is awake and the computer is operational
I am typing this looking at an aoc monitor attached to a pc ;
Sep 13, 2017 | AOC 931SWL 19 inch Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
My HP 2009m goes into sleep mode & shuts down
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
Feb 15, 2010 | Computers & Internet
Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
Aug 21, 2009 | Acer V223WBD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor is in sleep mode and I here a beep periodically
Try change the keyboard, if the pc does not detect the keyboard or a key from the key board is stuck which gives something like tic tic sound. On the other hand the display from monitor "sleeping mode" indicates the VGA cord is faulty or monitor is no compatible to the PC's video card.
Nov 26, 2008 | HP Computers & Internet
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Hanns.G Corporation HU-196DP LCD Monitor Logo
165 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
