If that doesn't work here is another tip on how to install Sentry Safes batteries that works on older models. Slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. Reconnect the connector and put back the battery holder. Slide the cover back in place. Need more help call a good locksmith.
Hi, Afraid to ask, but is it that you need to know how to put batteries in? If so Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Could be the battery holder is bad. A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
a1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Locksmiths agree on how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
Locksmiths say this is how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
To install sentry fireproof safe battery slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Sentry Home Safes battery location slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, next replace the electronic lock case and turn to the left to reassemble.
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
put in code and door wont open
