Question about Bosch & Tankless LP Hot Water Heater
Needing part to fix my water heater?
BOSCH SPA 80 RETRO EXTERNAL HOT WATER NG
I need the part that activates the ignition to light the heater,it has a 24v power supply and works when the spa pump is turned on.If there is a way i can send you a photo,please let me know.
  • Thomas F. Schneider May 11, 2010
    Type "Bosch water heater parts" into Google and you will get a page full
    rull of places to get parts, for it, from.
  • 34 Answers
Colburns Suppy they have a web site and will have that part in stock or they can order it. www.coburns.com
Posted on Feb 05, 2009
Hi, I have the 1600 NG tankless water heater. Everything works great, but I installed low flow hot faucets throughout the house and now the igniter will not click on. It works for the washing machine. ...
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#flow
1) Tankless require minimum flow rate before burner will activate.
2) Sounds like the water pressure drops quickly when faucet turns on. This implies combination of problems including sediment build up inside lines, crossover at single-handled faucet, or sediment filter clogged or water softener clogged.
3) Low flow faucets can reduce needed flow rate.
4) Other problems can contribute: sensor failure, loose wires, PC board failure, high temperature setting, cold incoming water temperature during winter months.
Jul 20, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I have a Bosch GWH 2700 CTDR EFS NG and the water will not get hot and if it does, it's only for a brief moment.
A lot of factors, internal and external, can cause this problem ranging from bad PC board to plumbing problem.
Since you have no error code, it could be plumbing,
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open following link for useful Bosch troubleshooting information including Bosch support and typical manual for 2700 gas tankless:
For folks with Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 26, 2011 | Bosch AquaStar 2400ES-NG
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Aquastar 125b ng: after 2 years of use water is not hot enough
Sounds like hard water. Service the water valve. Parts are available from your local Bosch Service Provider (Contact Bosch if you don't know who the service provider is).
Feb 03, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
I have a Bosch Aquastar 125ng with the water turbine ignition. When you turn on the water, it works exactly as expected. If you shut off the water and then turn it on again, it will not always start. It...
i have an aqua star 125 ng an the pilot lights and stays lit but the main burners wont fire up when i turn the water on i have good water pressure so i kind of stumped and i just rebuilt the diaphram in it also
Dec 11, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch & Tankless LP Hot Water Heater  Logo
168 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
