Question about Epson Stylus CX5400 All-In-One InkJet Printer
Paper feeder on epson cx5500 won't grab double sided paper
Can the paper feeder be adjusted for heavy weight paper?
    Guru:
  • 829 Answers
Hi ,
No You cannot there is limit for the printer to take on the paper , For heavy duty printer you need to check on some other printers.
Posted on Feb 01, 2009
Epson 810 automatic feeder won't feed
do you let the paper get pulled by it'self? Maybe try to push it and maybe it will grab it better to pull through...if not try a shop to fix or buy new one.
Sep 09, 2012 | Epson Artisan 810 AllInOne InkJet Printer
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Epson CX4800 no longer will grab paper.
Problem with paper feeder, Take to epson service center for replacing. Or if you have experience in maintenance, you can add thickness of pick up rubber at paper feeder mechanic (only top side). You can use sponge double tape (about 1 mm thick, and 1,5 cm wide) below the rubber
Oct 18, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Ref EPSON STYLUS 680 printer paper feed problems ,fails to feed paper but motor runs
try to look on the input tray maybe there are some foreign object that might block the paper,because this kind of printer has a durable pick up roller.
Sep 09, 2009 | Epson Stylus 680 InkJet Color Printer
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson 10,000 won't print on posterboard
Prints on 44" Wide paper up to 1.5mm thick
Does this help at all?
May 29, 2009 | Epson Stylus Pro 10000 InkJet Printer
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
281 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
