Konica Minolta bizhub 250 All-In-One Laser Printer
Problem for Konica Minolta bizhub 250 All-In-One Laser Printer
Bizhub 250 c1183 fault code
By hally on Aug 01, 2007
once the unit is powered on the main screen appears for about 2 seconds and the following appears...
Malfunction detected Fault code c1183...
All cables are plugged in.
Any help would be appreciated
Comments:
Mar 09, 2008
- Hi its hally. I found out the solution to my problem. There is a plastic paper tray that has to be slotted into the side... We didnt think we needed it. But the photocopy machine has sensors that need this paper tray hooked into the side of the machine to work. Simple problem to fix and im suprised no one said it.
Same Problem
Oct 31, 2009
-   I HAVE c-4554 PROBLEM WITH MY C-353-   wasi_hot
Jun 07, 2008
-   once the unit is powered on the main screen appears for about 2 seconds and the following appear:
Error code c1183...
Contact the service-   Guest
Mar 03, 2008
-   on a 450 with finisher. We swopped the finisher, but still does it! have changed power supply on main machine.HELP-   Guest
Best Solution
posted on Jul 28, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had a similiar problem with a Bizhub C-353. I tried opening closing the front door several time & power cycling galore. Turns out a had a loose on the saddle tray sensor. I wish the stupid thing would have just said "Finisher tray full" or something close to it.
efiRules
Solution #2
posted on Mar 08, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After machine off/on, the front door must be opened and closed to reset the finisher codes.
Solution #3
posted on Aug 17, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
put finger in power socket
Solution #4
posted on May 27, 2009
Not Rated)
wolfrecon
Rank: Apprentice
Rating: 0%, 0 votes
Call Konica Minolta's Service Department 1-800-456-5664.
Was this helpful?
Yes
No
Popular Solutions for Konica Minolta bizhub 250
Questions and Unsolved Problems for Konica Minolta bizhub 250
Do you recommend Konica Minolta bizhub 250 All-In-One Laser Printer?
Answer
Answer
Hi, My Konica minolta 210 printer gives me an error msg and it doesn't print and I have the driver... (More)
Answer
How do I print double sided? The "Print Type = Double Sided" check box isn't doing it.
Answer
it keeps printing blank sheets of paper and the LCD Display reads Callibrating Scanner??
Answer
Have a bizhub C353 conected to a network. Using a Windows domain. trying to scan to a network... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
