Question about Pioneer VSX-90TXV Receiver
Pioneer vsx 90txv and bose EQ
I have a pioneer vsx-90txv receiver i want to incorporate a set of Bose 901 VI speakers in my 7.1 sound system. the problem is the speaker need the bose EQ the run the speakers properly. i can't seem to find a preamp out then back into the receiver to run the front spekers using the EQ.
    Brigadier General:
  • 8,546 Answers
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Posted on Apr 25, 2009
  • 1 more comment
  • David Dunn
    David Dunn Jun 19, 2009
    You must have a separate amplifier to drive the 901's, with the Bose EQ in between a pre-amp out on your receiver and the new amp for the Front speakers (901's).
    Even if you could connect it in the traditional Tape Monitor configuration it would affect ALL of your speakers with stereo sources and using the Tape Monitor actively would disable any digital sources. Get a nice 100 watt/ch amp. I use a Carver AV-406 5-channel amp with my Pioneer VSX-36TX to drive the 901's (with EQ); the Rear Center and two Subwoofers.
  • David Dunn
    David Dunn Dec 28, 2009
    I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
    ** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
    Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
  • David Dunn
    David Dunn Feb 16, 2010
    On digitsl AVR's, anytime you activate a Tape Monitor it would disable the digital source, so the 901's Active EQ in a Tape Loop would not work with digital sources.
    What you need is a dedicated amplifier for the 901's. I have had mine running on anything from 400 wpc to my current 100 wpc. Feed the Front L and R Pre Outs to the Active Eq and then its output to the new amp. Go through your speaker level setup and rock on.
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Posted on Apr 24, 2009
Harmon kardon avr 146 with Bose 901 EQ VI
Bose is a pain in the back like Apple. Everything they make is proprietary or it won\'t work. The 901 series is one of them.
Nov 22, 2013 | Bose Audio Players & Recorders
I have a Bose 901 Series VI speaker system & have recently purchased a Pioneer VSX-1020-K AV Receiver. How do I connect the 901's EQ to this amp. I believe the only option is the CDR/TAPE IN/OUT...
This receiver has no pre-amp outs to drive the required separate amp the 901's need for you to continue to have multichannel digital audio. The reason: activation of a tape loop disables digital inputs. But they DID give you Front Height. Oh boy.
Sep 15, 2010 | Bose 901 VI Main / Stereo Speaker
Pioneer vsx 1020 K receiver. I connected the bose 901 eq to the tape in and tape out but it doesn.t seem to be compatible.
It would be compatible if you ONLY listened to stereo ANALOG sources on ONLY Bose 901's. Engaging any device in a tape loop automatically disconnects digital sources. Bose Active EQ is not intended for anything BUT Bose 901's. The sub could be destroyed by it.
Lacking appropriate Front Left and Right volume-controllable pre-outs on the 1020k, you can't use the 901's for multichannel or digital source material unless you accept a severe compromise and get a separate amp for the 901's borrow mixed-down stereo from the Pioneer's Tape Out, run it through the Active EQ to the new amp and manually manage the external amp's volume.
You need Front Pre-outs.
Jul 20, 2010 | Bose 901 VI Main / Stereo Speaker
I have a pair of bose 901, v1 I have a old pioneer vsx 5300
Not knowing anything about your specific amplifier or if it correctly configured for the 901 Active Eq, the first thing I would say is these are designed for analog stereo sources ONLY and a multichannel digital-capable receiver will NOT work properly with any devcie in a Tape loop.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
May 14, 2010 | Bose 901 VI Main / Stereo Speaker
901's directed to TV
Yes, you can plug your TV directly into the Bose 901 Equalizer, but you will still need to go from the EQ into an amp to drive the speakers. The Bose EQ basically is for the speakers, not the signal coming in to it. Because of the speaker design, the EQ "shapes" the sound to compensate for the speakers. Please rate my answer, thanks.
May 22, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Pioneer VSX-90TXV Receiver Logo
436 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
