I am in need of Windows sheduling concepts with buffer algorithm and it's codings
    Problem Solver:
  • 10 Answers
Let me know when u get that ?
Posted on Dec 01, 2009
Question 1: Find out the reasons those have made the UNIX an amazingly successful operating system. What are the Features on existing UNIX based operating systems like Linux Red Hat, Fedora and Ubantu...
Question 4: Consider the following set of processes that arrive in the ready queue at the same time:
Process CPU time
P1 2
P2 1
P3 4
P4 3
P5 1
P6 2
Consider the following scheduling algorithms: FCFS, SJF and Round Robin (quantum = 1)
(i) What is turnaround time of each process for each of the above
scheduling algorithms?
(ii) What is the waiting time of each process for each of the above
algorithms?
Jan 06, 2011 | Televison & Video
The Seagate encryption algorithm works for files 4GB or smaller. It will however encrypt larger files but it will not decrypt them! How do I decrypt files larger than 4GB ? Seagate admits there is a...
That posses a problem. They know there is a problem with the algorithm but don't plan to fix it. Wonderful. The problem is this, you would have to know what the algorithm was to be able to do anything about it and I doubt very seriously they are going to release that. That leaves you with the option of hiring a hacker to break the code or paying a specialty company to break the code and they are not cheap or well advertised. I can't think of any companies that do that work anymore. You are going to have to identify a Security company or the company that originally developed the Algorithm and see if you can work out a deal to get the corrected algorithm. The problem you have is your algorithm was designed for files smaller than 4gb and there is a permutation error that occurs on files that are larger. In a lot of cases this is a random fault that makes it very difficult to identify if not impossible depending on what level of encryption the algorithm actually represents. 32 or 64 bit encryption isn't so bad but 128 or higher is a real pain and expensive. There are some software packages available out there if you search the web for them, "Decryption Software", but again it is expensive and hard to find.
Dec 16, 2010 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Code of DES algorithm using C++
Why can you not just use an existing encryption library? It will be much more reliable. If on windows you can use the MS CryptoAPI library to encrypt using the DES.
If you still wish to make your own algorithm I found a page with javascript, perl, and php examples you can use to base your own custom conversion on at http://tero.co.uk/des/code.php
Apr 16, 2010 | Computers & Internet
Implemation of booth algorithm
check this out buddy...
http://cpsourcecodes.com/?tag=booths-algorithm
u may need to modify it a little, but you are a programmer so it shouldn't be any trouble... :)
Mar 24, 2009 | Computers & Internet
Data mining
Hello, you can find the best open-source implementation of data-mining algorithms here:
http://www.cs.waikato.ac.nz/ml/weka/
You can use the built-in application or embed it in your own code.
Of course it implements several naive bayes algorithms
Mar 20, 2008 | Computers & Internet
Actovaion code windows vista
Sorry, you must buy the product in order to receive an activation code. Just handing you a code is PIRATING. No one here can help you with that.
Feb 23, 2008 | Microsoft Windows Vista Ultimate Edition
Linksys adapter
Factors that Affect Voice Quality
  • Audio Compression Algorithm
    Speech signals are sampled, quantized and compressed before they are packeted and transmitted to the other end. For IP Telephony, speech signals are usually sampled at 8000 samples per second with 12-16 bits per sample. The compression algorithm plays a large role in determining the Voice Quality of the reconstructed speech signal at the other end. The SPA supports the most popular audio compression algorithms for IP Telephony: G.711 a-law and µ-law, G.726, G.729a and G.723.1. The encoder and decoder pair in a compression algorithm is known as a codec. The compression ratio of a codec is expressed in terms of the bit rate of the compressed speech. The lower the bit rate, the smaller the bandwidth required to transmit the audio packets. Voice Quality is usually lower with lower bit rate. However, Voice Quality is usually higher as the complexity of the codec gets higher at the same bit rate.
  • Silence Suppression
    The SPA applies silence suppression so that silence packets are not sent to the other end in order to conserve more transmission bandwidth. Instead, a noise level measurement can be sent periodically during silence suppressed intervals so that the other end can generate artificial comfort noise that mimics the noise at the other end using a CNG or comfort noise generator.
  • Packet Loss
    Audio packets are transported by UDP which does not guarantee the delivery of the packets. Packets may be lost or contain errors which can lead to audio sample drop-outs and distortions and lowers the perceived Voice Quality. The SPA applies an error concealment algorithm to alleviate the effect of packet loss.
  • Network Jitter
    The IP network can induce varying delay of the received packets. The RTP receiver in the SPA keeps a reserve of samples in order to absorb the Network Jitter, instead of playing out all the samples as soon as they arrive. This reserve is known as a Jitter Buffer. The bigger the Jitter Buffer, the more jitter it can absorb and the bigger the delay it can introduce. Therefore the jitter buffer size should be kept to a relatively small size whenever possible. If jitter buffer size is too small, then many late packets may be considered as lost and thus lowers the Voice Quality. The SPA can dynamically adjust the size of the jitter buffer according to the network conditions that exist during a call.
  • Echo
    Impedance mismatch between the telephone and the IP Telephony gateway phone port can lead to near-end echo. The SPA has a near end echo canceller with at least 8 ms tail length to compensate for impedance match. The SPA also implements an echo suppressor with comfort noise generator (CNG) so that any residual echo will not be noticeable.
  • Hardware Noise
    Certain levels of noise can be coupled into the conversational audio signals due to the hardware design. The source can be ambient noise or 60Hz noise from the power adaptor. The SPA hardware design minimizes noise coupling.
  • End-to-End Delay
    End-to-end delay does not affect Voice Quality directly but is an important factor in determining whether subscribers can interact normally in a conversation taking place over an IP network. Reasonable delay figure should be about 50-100ms. End-to-end delay larger than 300ms is unacceptable to most callers. The SPA supports end-to-end delays well within acceptable thresholds.
Dec 01, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
