Question about Sony Ericsson W550i Cellular Phone
USB Connection Not Detected/Device Unknown
My phone has always worked with my computer but, I turned on the computer and plugged it all in to transfer some pictures and my computer gave me an error that read USB Device Unknown. So I unplugged the phone restarted it tried again... Same error. Then I restarted it without unplugging my phone the device was found and the computer said it was working properly but I cant find the folder under My Computer> that stands for the phone? Any suggestions for fixing this nuisance of a problem? -SP
  • 1 more comment
  • Shari  Pearson
    Shari Pearson Aug 01, 2007
    I am running XP... It is the origial cable, its not damaged though... In device managaer the phone isnt showing up at all anymore...
  • Shari  Pearson
    After the phone stopped working i kept just not using it for a day or two and using my computer like normal, turning it off and occasionally seeing if the phone didnt work. I called the repairman that I usually go to and he said to update the computer with the microsoft updater and i did but it hasnt helped or done anything, thats the only update taht has happened and it was nothing to do with the drivers.
  • raj7 Dec 17, 2008
    i have w200i,and pc suite is installed in the computer,when i connect my phone to the computer using a usb cable ,in the phone display it shows that is phone is connected to the computer ,but in the computer the phone is not detected....but i have something which say sony ericson under device manager,usb adaptors..i tried scanning for new hardware changes it is not detected by the computer....
I have same problem, eventually i can solve it by pressing the primary button (clear big middle button) while i plugged in the usb con. The chance to get it is only for few milisecond due to preparing menu will flashing immediately,  it will force my phone to prepare to preparing usb connection
Posted on Dec 01, 2008
I think your phone's memory capicity is full or your actual storage sysystem of your phone is buggered. hope it helped. p.s or your computer doesnt function properly.
Posted on Aug 01, 2007
  • 944 Answers
What operating system do you have on your computer? Are you using the original USB cable or a replacement? Have you recently updated/changed your USB drivers or phone firmware or formatted your phone? If using windows XP then does the phone appear in "Device Manager"? Waiting for your info :)
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
How to down load pics from LG cell phone to Windows
Because I run Linux on my computer I could not run the software that came with my KC910. I was able to transfer my pictures using a bluetooth connection but it seemed to take forever. I purchased a bluetooth connection device that just plugs into a USB port.
What I do that works fine for me is to place my pictures on the SIM card and transfer them that way. Just get a USB SIM card reader and plug it into your computer. It will act just like another device and you can copy, edit or do whatever from there.
Hope this helps.
Nov 23, 2011 | LG Cell Phones
Hi! i have USB detection problem: PC does not detect N97 mini (USB connection not detected), thank You for help, Edyta
Try installing PC suite once again. also check the drivers for the USb cable.Try plugging any other USB device in your computer. if it doesnt work, then usb port on your computer is bad,.
Nov 22, 2009 | Nokia N97 Cell Phone
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
WHEN I PLUG MY USB CABLE INTO THE COMPUTER IT SAYS UNKNOWN DEVICE. WHEN I RIGHT CLICK AND CHECK THE PROPERTIES IT SAYS THERE ARE NO DRIVERS INSTALLED
yu have to first install it usin the pc suit given to yu.. aftr that yur usb cable will get detected automatically...
Jul 07, 2009 | Cell Phones
When I plug my 4gb flash it say malfunction and not recognize
have you tried putting it in a different usb port if you tried that try updating your computers usb drivers from the support site for the computer your trying to use the flash drives on
May 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Ku990 mobile to pc connection fail.
Yes janne_y_ang, I would have to tell you that from my own personal exprerience from using this phone has lead me to the conclusion that using BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo....
  • 2.Select setting
  • Press Mass storage
  • Press OK.
  • 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
    Dec 07, 2008 | LG KU990 Viewty
    Transcend 4gb pen drive not getting detected
    pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
    Jul 23, 2008 | Transcend (589307) Media
    I plugged my Memorex TravelDrive into my computer. It has always worked perfectly. This time I got the message that the USB device was not recognized and I can't get into my files.
    THE FOLLOWING IS COURTESY OF MICROSOFT Help and Support
    When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
    Unrecognized device has been found.
    This issue occurs because, when the computer comes out of S3 or S4, there is a five- to ten-second period when the selective suspend feature of the USB driver will interfere with detection of a new USB device connection. The time period depends on several factors. This includes the following factors:• Host controller hardware
    • Attached hubs
    • Attached devices
    • USB driver versions
    • Support for USB 2.0
    • Additional system hardware or configurations that may change the timing
    There may be other reasons that a USB device is not detected
    Method 1
    loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
    Method 2
    After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
    Method 3
    Use the Device Manager to scan for new hardware. Follow these steps: 1. Click Start, click Run, type Devmgmt.msc, and then click OK..
    2. On the Action menu, click Scan for hardware changes. This causes Windows to recognize new devices.
    3. Close Device Manager and Control Panel.
    Method 4
    Disable power management of the USB hub.
    Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
    To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK.
    2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties.
    b. Click the Power Management tab.
    c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
    SIMILAR PROBLEMS AND SOLUTIONS loadTOCNode(1, 'moreinformation'); For more information about advanced troubleshooting tips for general USB problems, click the following article number to view the article in the Microsoft Knowledge Base: 310575 (http://support.microsoft.com/kb/310575/) Advanced troubleshooting tips for general USB problems in Windows XP For more information about how to troubleshoot unknown devices in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 314464 (http://support.microsoft.com/kb/314464/) How to troubleshoot unknown devices that are listed in Device Manager in Windows XP
    Try restarting the computer with the device in. Sometimes if you clear the memory that might help (stating the machine without memory then put it back and start it again).
    Jul 01, 2008 | Computers & Internet
    Unknown device
    this is an error message stating that. the usb device is faulty.
    It has detected that the usb port has an error/fault or problem.
    check that non of the pins are touching each other, or that dirt or dust isn,t inside the usb connection port. blow in it. or use a cotton bud to swab it out.
    Mike @ Compurepair.
    Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
    Sony Ericsson W550i Cellular Phone Logo
    333 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
