Question about Armada T-Hall Skis
Black ooze! I have just returned from skiing with my Salomon X Scream monocoque skis. I was giving them a wax before storing them for the next year when I noticed a black sticky ooze emanating from the Prolink strengtheners (?) fore and aft of the bindings. This was easily cleaned with white spirit. 1) Is this a problem? 2) Do the Prolinks contain some sort of oil? 3) Do I need to get this rectified before using them again? 4) If so, would an ordinary ski shop that offers tuning, at a resort, fix the problem? Thanks for your help.
  • Anonymous Feb 17, 2009
    I noticed this on my X-Scream Series about a year ago. I suspect that there is some sort of gel in the prolink that gradually absorbs water over the years. It's sticky, and messy, but doesn't seem to affect the skis' performance yet, and I don't think that it's a safety concern. I'd quite like to stop it though.
    I've checked the Salomon web site for a contact, without success, so unless there is someone out there who can help I think we'll have to take our skis to a mechanic...
Ski replacement
take your pick :>)
Snowmobile Skis (Universal) - BikeBandit.com
www.bikebandit.com > Aftermarket Parts > Tracks & Skis Items 1 - 20 of 20 - ... at BikeBandit.com. The Web's most trusted source for Snowmobile Skis (Universal). ... AFTERMARKET PARTS ยท Shop Aftermarket Parts by ...
Camoplast Camoski Plastic Ski Kits ' Snowmobile Parts ...
www.mfgsupply.com > ... > Skis and Accessories. > Skis & Ski Shocks Camoplast technologically advanced blow-molded Snowmobile ski. Lightest weight ski on the replacement market.
OEM Snowmobile Parts and Snowmobile Accessories for ...
www.dirtcheapsnow.com/ Get your motor going with genuine OEM Snowmobile parts and aftermarket accessories at the best price for your Polaris, Ski-Doo, Arctic Cat, and Yamaha ...
Snowmobile Replacement Body Parts - Dennis Kirk, Inc.
https://www.denniskirk.com/snowmobile/replacement-body-parts Results 1 - 38 of 191 - Shop the best selection of Snowmobile Replacement Body Parts at Dennis Kirk for the lowest prices. FREE SHIPPING on orders over $89 ...
Aftermarket Ski Options - Snowmobile.com
www.snowmobile.com > Products Oct 16, 2008 - Aftermarket Ski Options: Most snowmobilers rarely give their sled's skis a second thought until that day when the sled seems to have a mind of ...
Jan 15, 2016 | Winter Sports
Tip
Wax your ski and check that the pole lish is strong
before every ski vacation
make sure your ski is waxed enough and that the hand lish ia stron enough
on Jan 19, 2010 | Flow M9 Snowboard Binding
My Dept56 animated ski mountain. The skiers seem to heavy for the magnets in the ski run
Cut the friction on the skis or ski slope, use wax or soap to cut down on friction
Dec 16, 2014 | Sport & Outdoor - Others
Where can I buy ski and snowboarding gloves?
You can buy ski and snowboarding gloves at the main manufacturers' store (ie. The North Face) and other local stores, as well as online in many different websites such as: http://www.backcountry.com/ski-gloves.
Feb 06, 2013 | Winter Sports
Where can I buy water-skiing equipment?
You can buy water-skiing equipment at local stores or on the internet.
Feb 06, 2013 | Water Sport
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
Jan 17, 2013 | Winter Sports
How to maintain my jet ski?
If you plan to store a jet ski in a garage, you will need to make sure it is dry and cool and with limited exposure to the sun. In general, you need to do what you can to prevent rust and other grime that eventually may cause mechanical issues.
Washing your jet ski is also needed after every use. You can use your car wash products. I also suggest to read the user's manual, it may include tips about maintaining your jet ski.
You can protect the engine with a special spray and water repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
Jan 17, 2013 | Boating
What is the best brand of ski wax?
Brand is not so important as to the type of wax used. You want to make sure the wax is right for the conditions you will be riding. Some wax is harder than other wax and will work better in different conditions. Some wax is made for very cold temperatures -20 degrees Fahrenheit and below, some for intermediate temperatures, and some for warm temperatures, higher than 32 degrees Fahrenheit. Rub on waxes work well for an hour or two but quickly wear off. Hot waxing is best, but takes some time to apply and to learn how to do yourself, or usually costs at least $20 to have someone else do it for you.
It also depends on what type of riding you will be doing. If you are racing, you will want the best wax possible, and this is where brand and formula of the wax is important. It's best to talk to fellow racers in your area to find the best wax for that area's conditions if you are racing. Otherwise, any brand made for the temperatures you will be riding will be fine and any differences in speed from brand to brand will be unnoticeable.
Feb 15, 2011 | S3 Toko Hot Wax For Ski And Snowboard
Vertical adjustment on front binding. Salomon S810 Ti
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
Nov 07, 2009 | Rossignol Used Freeride X 05 Skis with...
Armada T-Hall Skis Logo
367 people viewed this question
Top Armada Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you an Armada Boating Expert? Answer questions, earn points and help others
