Question about Freezers
Fan in freezer very loud noise
I bought a beko fridge freezer nov 207 and the fan has gone very loud model number cda659fs 11.3cf thank you for your time
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
Posted on Jul 09, 2009
    Problem Solver:
  • 10 Answers
Usually, when a fan gets noisy it is because ice has built up on the evaporator, and the fan blade is hitting the ice, easiest way to find out is to defrost the freezer, then switch it on again, but it could take 48hrs to fully defrost. do not use heaters.
if it works ok then, you have a automatic defrost cycle problem which will be electrical, and expensive.
your freezer should work fine for a while, maybe a couple of months, until the ice builds up again.
Posted on Feb 07, 2009
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
I have a BEKO CDA539F and notice that there is one with an X attached to the end of the code that is amongst the recall models. I asssume that my fridge freezer is safe. Am I correct?
From what I understand, you are safe if your serial number does not match the ones in the list exactly. That said, the information I have is from knowledgeable sources but NOT from BEKO, who have failed to answer their 0800 incident line or reply to my mails for 4 days now (By coincidence, while I provide a lot of technical help on this forum, I also have a BEKO fridge that IS on the list).
I would go to their site and send in a mail via the facility they offer there. I imagine that at some stage you will get a confirmation that all is OK with your fridge, but I would want to cover the bases if I was in your position. For convenience, the original article I wrote with the BEKO website listed in it is reproduced here for you:
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
The site also provides a mail address and a UK Freefone number that you can call (Though I've tried the number and it keeps cutting me off!! I presume they are swamped with calls)
Jul 09, 2011 | Freezers
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
the hose out of the back of my fridge freezer is loose is this right and there is a bad oddur
Dec 09, 2009 | Freezers
I have a beko fridge freezer. I had an error code
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Jun 18, 2009 | Freezers
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Beko fridge freezer
Is it froze up? maybe it needs defrosted.
Jan 19, 2008 | Freezers
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
708 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
