Question about Intel DG31PR Motherboard
Can't see 1440x900 resolution in display settings. in LG w1942s
I bought a new Intel C2D with Intel DG31PR motherboard and monitor. I LG w1942s installed intel display drivers, monitor drivers But still I can't get 1440x900 resolution which is recommanded for the monitor.
  • 1 more comment
  • bimal_aau Feb 11, 2009
    I Have same Problem
    LG w1942s installed intel display drivers, monitor drivers & update latest driver. But still I
    can't get 1440x900
    resolution.
    when reboot my PC than some time resolution change.
  • Francisco A
    Francisco A May 11, 2010
    That resolution is covered but it might be that you need to update your video drivers for that motherboard and try again.
  • swufabuda
    swufabuda May 11, 2010
    Just because that is the resolution that your monitor recommends does not mean that your graphics card is capable of such resolution. It's your graphics card that sets your limit on resolution not your monitor, in this situation anyway.
  • 1,602 Answers
Go into the refrash rate and change it to something other than what it is you may need to go up or down it depents on the manufacture settings. also they may say the monitor can do it but it cannot do it, drivers are a big factor also.
right click, select the vedio card options, software option for the card, or properties, display options
control panal, open up personalization,diplay settings, advance setting, choose the best option for your needs.
rod
Posted on Feb 05, 2009
I use intel DG31PR motherboard.. and when i boot again my computer after shutdown it.. my monitor won't display and if it displa.. it stock on the BIOS.. what may cause this kind of Problem?
Try pressing f8 on boot-up and select safe mode.
If you can get into safe mode then all you need to do is decrease your screen resolution in display settings to 640X480 then click apply and reboot the computer. after reboot gradually increase the screen resolution a click at a time until you get it back where you want it at.
Aug 24, 2010 | Intel DG31PR Motherboard
In my syatem, start with no display after windows
start windows in vga mode by pressing F8 at starting after POST. then set the resolution of your screen to 800X600 and restart.
Dec 21, 2009 | Intel DG31PR Motherboard
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Monitor resolution
What do you mean that you were unable to get the native resolution of 1440x900? Are you saying that the resolution varries?
Since you mentioned that the mother board supports 1440x900, try to set the monitor resolution to that same resolution and then restart the computer.
If you will get the same problem, you have to make sure that the video card supports 1440x900 resolution.
Apr 15, 2009 | LG L194WT 19" LCD Monitor
MONITOR RESOLUTION PROBLEMS
This is a limitation of your video card. First, make sure you have the most up to date graphics driver available for the video card that you have. If that doesn't help, then you will need to add or replace the video card.
Thanks and please take a moment to rate as fixya.
Dec 11, 2008 | LG W1942T-SF Monitor
1440x900 resolution required
check and make sure that you are using the Intel drivers and not the default windows xp drivers. The default drivers are very limited and only offer a few different resolutions to choose from.
Nov 20, 2007 | Intel D845GVSR Motherboard
Intel DG31PR Motherboard Logo
1,799 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
