Question about Nokia N73 Cellular Phone
Disk error - cannot copy or complete task
I am getting this mssg when I am starting my phone, even the memory card is not working and back side camera also not working, i formatted it several times, but fails. Please help me
  • 89 Answers
Format using this procedure:-
1)Turn off your phone.
2)keep pressing *, 3, green call key and turn on your phone while keep pressing these keys(including power key).
3)you will see ascreen soying "formatting".
Posted on Feb 01, 2009
Greetings! I have a SanDisk M2 memory card for my
-u- can always contact geek patrol tell them what -u- -r- going through they may have the answer -u- -r- looking for//
Oct 29, 2013 | Electronics - Others
Communication error
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jul 19, 2013 | Canon PowerShot SD1100 IS Digital Camera
I have a nikon coolpix s210 I can take 34 pictures and then it says out of memory, then it deletes them on the memory card. When I take the memory card out of the camera the 34 pictures are still on the...
Your camera is fine. It is not writing to the memory card...only to it's own internal memory which is very small. To get it to start writing to the card, you must get rid of the pictures in the internal memory. If you want to save them, go into the menu and find "copy" to find the choice to copy the internal memory to a card. After the process is completed, turn off the camera, remove your card, turn the camera back on and go back into the menu...find "format" and follow the on-screen instructions. After that, your card should work properly.
Mar 27, 2011 | Cameras
When iam copying any thing from my pc to my mobile It shows error copying file or folder make sure that the disk is not full and write protected and file is not in use..... but they all are wrong...
check the memory card if its working fine. the memory card might be corrupted thats why it aint accepting any files coming in from your PC at all. hope this helps
Feb 12, 2011 | Computers & Internet
Disk error - cannot copy task
I am sorry to know about this buddy. It seams that there is some problem in your cell phone. I suggest you to contact the service center of your cell phone, as they can only assist you in this case. The cell phone is not accepting the original formatting concept.
Feb 01, 2009 | Nokia N73 Cellular Phone
Memory stick error
Hi There, In the menu there should be a setting to set the camera back to factory. Try re-formatting the card. Try using a different card. The camera has some built in memory, take card out and shoot 2 pics on built in memory, is playback ok?
If not, card reader may be defective. Only service shop could tell you that for sure.
Let me know, mr cicmo.
Dec 28, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
3650 phone start up failed pls help me
u have to reset or mobile ..to do that follow this
1. Removed your MMC card first.
2. Make sure you have at least 3/4 charge of battery before performing the
" Safe Mode, and follow-by phone reset *#7370# ". Or maybe you can have the
charger on and plugged into the phone to act as a full power source.
3. Press and hold the ABC key and then press the power button.
Remember not to release the ABC key till you seen the
"Safe Mode" standby screen.
(Fyi, there's no special indicator that telling yo're on a "Safe Mode"
standby screen.)
4. Once in the "Safe Mode" stanby screen press *#7370# to carry-out "Phone Reset"
task.
5. Once "Phone Reset" task completed and back to normal standby screen again,
switch off your phone and re-insert your MMCmag-glass_10x10.gif card.
If any error showing on the phone boot-up, please have the memory card formatted and by next phone
start-up you will not have the error msg again.
If you some important data or programs files on your MMC card, please use
a card reader to have them copied onto a pc before performing memory card
formatting
Dec 04, 2008 | Nokia 3650
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Cannot Copy {filename}: Parameters are incorrect
First suggestion: Make sure the battery in the camera is completely charged and try again.
Your best bet is to use the card reader when it arrives. Sounds like a corrupt file on the memory card. Be sure to completely format the card (not just erase pictures) after you successfully get the images off. And I suggest running through a complete set (full card) of images that you don't care about (shoot your backyard) before you trust that memory card again.
Memory cards are (relatively) cheap, so consider replacing the card soon.
Dec 17, 2007 | Nikon D70s Digital Camera
Nokia N73 Cellular Phone Logo
167 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
