Question about Bose 3 2 1 GSX System
How do I get the audio from the Tv to play through my BOSE 321 sy
I have a yellow cable going from monitor out to audio in and it is not playing the sound from the TV through the system. What am I doing wrong
    Problem Solver:
  • 19 Answers
Using remote try all ...AUX - Video1 - Video2 u will find which one it is connected to.
Posted on Feb 11, 2009
I have an RCA rear Projection TV model # p60812BL manufactured in 1998, no sound is coming from the tv when watching cable TV via a digital box. When the mute button is pressed and unpressed you can hear...
Tries tv and cable box unplug,replug it back like about an hour.For the tv resetting itself and the cable box to upgraded it softwares.Go into the tv menu go to Audio SETUP.Go down to audio ressetting,these steps should solved ur problems,but not call ur cable companny replaced the reciever box,it have problems.
Mar 16, 2011 | RCA P52926 52" Rear Projection Television
My viewsonic monitor has no sound. i can here a beep from the computer if i do something wrong but i cannot play anything on CD or U-tube
If the "error" beep is heard from the PC beeper, you have missing audio drivers in the operating system. Go to Control Panel, System properties, Hardware, Device Manager. Look for device marked with yellow question or exclamation mark. Use your motherboard driver CD to reinstall the drivers.
Aug 06, 2010 | ViewSonic VX1962wm LCD Monitor
Hooked up home theater system, sound but no picture
are the red and white for "audio in" to the theater system receiver and the yellow cable hooked up to "video out" on the receiver and "video in" on the tv?
Typically most theater systems do not have "audio out" connections because they produce the audio. The receiver will have several "video out" connections, one of which needs to go to the tv.
Mar 12, 2010 | Audio Players & Recorders
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Vcr hooked up, no audio
From the VCR to the tv if you have RCA cables its kind of hit and miss where the audio cord goes. Only one of the jacks are for sound but it has to be plugged in to the right input. Audio is usually the white one. Just keep touching it to inputs until you hear sound start to come out of the speakers. Hope it helps.
Jun 27, 2009 | Insignia Digital-to-Analog Converter for...
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
well I have a work around and a solution possibly. first go threw your menu audio and verify external speakers are not turned off. if there is no setting or it is turned on already try a different video/audio input if nothing else if you have good picture you can use a stereo reciever to play the sound you do not have to input audio into the tv if you have surround sound go straight from your device(dvd, vcr,cable box etc.) to your sereo reciever just the audio plugs (red and white, not yellow unless you have a monitor out from your stereo in which you conect all three to the stereo input then one cable from the monitor out on the stereo to the tv in put
Apr 14, 2009 | Televison & Video
How do I connect my Vizio 42' Gallevia to my DVD home entertainment center? I want it to play through my speaker system. I have tried the analog and the optical outputs but still get nothing. The only...
First check does home theater system has any audio input at rear? If yes, hooke up monitor audio out / tv audio out cable there to have TV sound through sound system by selecting that input.
Jan 03, 2009 | Televison & Video
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Bose 3 2 1 GSX System Logo
210 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
