Question about Car Audio & Video
Alpine cda 9887 Does anyone know how to change the Radio Tuner frequency stepping on this model to 0.1Mhz?
    President:
  • 1,990 Answers
I cannot locate any thing on this Subject anywhere in the Archives.
Posted on Feb 01, 2009
I have a cda. 9887. It powers on but gets no sound from any of the speaker wires. What could be wrong. What can I try.
Most Alpine CDA units come with an option to turn on/off the internal amplifier in order to give you better sound when connecting an external amplifier. Try turning on IC
Aug 15, 2011 | Alpine CDA-9887 CD Player
How to change tuner to pick up all frequence's eg: goes from 95.5 to 95.7 how do i get it to change to 95.6 thanks jason
It will only tune into odd numbered stations because US radio station only broadcast in odd number stations (ex 95.5,95.7,96.3). You can change the area. Area 1 is North America, Area 2 is other areas. Press "Menu"->"Setup"->"Tuner"->"Tuner Area", then select 1 or 2. After setting, press and hold "Menu" for at least 2 seconds. This may give you the frequency you are looking for.
Apr 14, 2011 | Alpine CDA-9855 CD Player
My cda-9887 does not have a bass/treble setting. Only fade/balance
In the initial stage of the set up your 9887 the stereo is set with an Equalizer (parametric or graphic), Until you use the Imprint set up module to Tune your car you wont get bass / treble controls. Also after Tuning with Imprint you will lose the EQ function, and it will only be B/T.
Nov 02, 2010 | Alpine CDA-9887 CD Player
Alpine 9887 no incoming power supply. Incoming vcc checked ok at conector level, 10 amp fuse block not blown
did you check power at both the red and yellow wires? also, make sure you have a good ground.
Sep 10, 2010 | Alpine CDA-9887 CD Player
Problem with the radio
THe frequency stepping cannot be changed on this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Alpine CDA-105Ri CD Players
Speakers dont work with CD, but work with radio.
I just had this problem with my e34 bimmer, just connect the blue wire to with the red wire (apparently the 9887 shuts off the antenna when the radio is off). so in my case, bmw thought it was a good idea to wire the two together, which means you go to CD and the Deck shuts off the amp, killing the speakers.
Nov 15, 2009 | Alpine CDA-9887 CD Player
Stations on radio will not set
A car radio needs two sources of power. A little bit of 12 volt all the time and more power when you want to hear the music. Also known as battery(all the time) and ignition (when the "power" is on). It might be a bad connection on battery power or it wasn't connected right. Battery power is needed to keep the presets and the clock setting.
May 17, 2009 | Alpine CDA-9887 CD Player
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
