Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
LG 211cm rear projection RT-48SZ40RB
When switched on amber light flashes 7 times then goes to red.Sometimes comes on after 4 amber flashes. Checked globe,looks o.k.
  • Anonymous Dec 08, 2007
    i had to replace the lamp of my lg mdp rt-48sz40rb 3times. and it's becoming enyoing.
    the first time i hade same case as yours. but after tv won't turn on.
    changing the lamp once is ok but 3times..
    Problem Solver:
  • 3 Answers
Power supply has packed up. It is common and cheap to replace on this telly. The replacement will pack too unfortunately.
Posted on Oct 04, 2008
    Problem Solver:
  • 18 Answers
The amber ight is a simple warm up procedure as it projection seems a power problem...
Posted on Aug 10, 2007
6ya staff
SOURCE:
LG RU-60SZ30 when turning the tv on the power lite changes from red to flashing amber, flashes 6 to 7 times then turns back to solid red. The tv never actually starts. Before this the tv would randomly...
I have read another solution which may indicate the light engine has failed and will likely need replacing. The cost is quite expensive. $1500 range and apparently the part is no longer available from LG. Best you might do is get an estimate to repair just to be sure.
Dec 04, 2010 | LG RU-60SZ30 60" Rear Projection...
I have a LG RU-52-SZ61D. It Shut down this morning, will come back on for a short time, then shuts down again. The Lamp Indicator light flashs several times and then goes out.
Problem on power supply.
Solve: If you fix this problem itself,change capacitor or power transistor,Drain section LT diode fault change it.then solve your problem.
Jan 10, 2010 | LG RU-52SZ30 52" Rear Projection...
LG Rear Projection 44" will not turn on
Make sure you reinstall the lamp door as there is a lamp door switch that must be closed or the unit will not fire the lamp, there should be a small hole or opening on lamp door housing. Some people install the lamp without reclosing the door just to see if the unit works , just to find out if it will not work, and when it does;nt think something is wrong, they do not put the lamp door back on first. Not to say this is the case but it does happen.
Jun 12, 2009 | Samsung HCN5527W 55" Rear Projection...
LG rear projection. RE-44SZ21RD - flashes amber
get a ohm meter and check all the fuses
Mar 27, 2009 | Televison & Video
LG Rear Projection TV RT- 48SZ40RB
Some say you can reset the timer in the service menu, normally accessed by holding down the menu button on the TV and the mute button on your remote at the same time. Others say you need a special "service remote" to access the timer. I've changed my bulb twice already and have just learned to ignore the amber lamp timer light. A little square of black electricians tape would make it go away!
Nov 03, 2008 | LG RU-52SZ51D 52" Rear Projection...
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
Regards
What About Bob
Feb 19, 2008 | Televison & Video
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
No picture-lg ru-52sz51d
Hi lovelace Check your power supply module it needs to be replaced.good luck
Apr 25, 2007 | LG RU-52SZ51D 52" Rear Projection...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
255 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
