Question about Buck Guitar Hero World Tour for for Xbox 360
Hi,can you help??the wire that connects the yellow symbol is broken completely off the black little thing that goes into the slot. the actual wire is coming out and i stuck it together with sellotape and it worked until it fell off and the wire has come out worse and its all screwed up and it wont go back in no matter how much i do. everything else works though. please help me and does anyone know if or where you can get a new yellow symbol? please and thanks for listening.
  • shannon_dood Feb 06, 2009
    nahh didnt hav to my dad fixed it,thanks anyway
    Problem Solver:
  • 11 Answers
Im sorry to tell you this but you will have to get a whole new drumset because nobody sells just a yellow symbol. (this has happened to my friends before and they had to buy new sets.)
Posted on Feb 02, 2009
Hey, I purchased your Honeywell RTH2510 Thermostat, but I didn't even think to label the wires when I took the old thermostat off. Upon installation of the new Thermostat (2510) the Air Conditioning...
The connections that you really need to reference would be at the air handler itself. That would tell you which wires go outside to the heat pump and which wires go to the air handler. I can however give you some basics that may help.
Heat Pump Wiring
Terminals/Colors/Function
R- Red- 24v power supply. (Usually a jumper between RC/RH)
G- Green- Fan
W- White- Heat (Sometimes W1-W2, first or second stage heat)
Y- Yellow- Cooling (Same applies as above i.e. Y1-Y2)
C- Common (Most people use blue unless it is used for B terminal and sometimes cooling on older 4 wire systems.
B/O- Reversing Valve for heat pump. Either powered heating or powered cooling, depending on system installed.
Aux- Also used for heat.
Note: Considering that the installer had their own way to run all wires, use different wires, connections, etc. This is just a reference to common wiring in the field.
How the most common system is hooked up:
Thermostat:
Red wire goes to R terminal
Yellow wire goes to Y1 or Y2 terminal
Green wire goes to G terminal
White wire usually goes to W1 or W2 terminal
Orange or Black wire goes to B/O terminal
Brown wire usually goes to Aux terminal
Blue wire goes to C terminal, unless its being used as stated above.
This is without using a fossil fuel kit or zone control board.
Where do they go from the thermostat?
Red
goes to the air handler transformer or board and goes outside to heat pump to power low voltage controls.
Yellow wire goes straight outside to Y terminals on heat pump unless going to a board inside first.
Green goes to the air handler fan relay.
Common goes to the air handler and outside to heat pump.
Black or Orange will go outside to heat pump terminals for reversing valve.
White usually goes outside to heat pump,and inside to air handler. Will explain reason further down.
Brown will go to the air handler to the heat relay for the emergency heat.
On a call for heat, with a powered cooling system (more common).
The R, Y, and G terminals energize, sending a signal to start the blower and pull in the contactor outside. Note that the Y terminal is usually cooling, but since this is a powered cooling system, the reversing valve is not energized, causing the system to run in heat mode. If you have powered heating, the reversing valve terminal will energize also. Depending on thermostat, if you set the temp substantially higher than room temp, it may kick on the emergency/aux heat to quickly raise the room temp. On a call for emergency/aux heat, the R, G, and E/Aux terminals are energized, turning on the electric/gas heat instead of the heat pump. This comes in handy since the heat pump can only pull so much heat from outside before its not enough to properly warm the house, usually around 30 degrees outside temp. If you are running the heat pump and the system goes into "defrost", the outside unit will send a signal back to the air handler, through the white wire I mentioned earlier, to tell the emergency/aux heat to come on while it is in defrost mode, providing heat whenever needed.
Again, this is just a reference guide to some basic wiring, but hopefully it will tell you where the problem is or at the least, give you a good start. There are variables in which things can change the wiring like a zoning system or fossil fuel kit. Even then, you should be able to get pretty close. Hope this helps and Happy Holidays!
Dec 07, 2013 | Honeywell Programmable Thermostat Heater
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Hi ! I have a Kenmore central vacuum (model # 34326), 3 inlet valves on different floors. the inlet valves on the second and third floors are already connected. I need to connect the inlet valve...
By your description it seems that You have telephone wire used. You only need two low voltage wires to complete the circuit to turn on the power to the central vacuum unit. The low voltage wires must be arranged so that when you insert the hose into any valve it closes the circuit. You will wire it as if the black and red are just one wire and the green and yellow are the other, they are actually doing exactly the same as if you only had two wires.
Mar 05, 2017 | Kenmore Vacuums
Maytag cse9000ade cooktop. Does anyone have
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
Kelly
May 03, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Both symbol wires broken
i agree withe you about geting an electricin but before you get him maybe something wrong with the symbol wires or the television
Jun 27, 2009 | Nintendo Rock Band for Wii
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
I had guitar hero since xmas and yellow symbol not working
How did you break the wire?
The best I can suggest is that since the drum kit is still under warranty, take it back to the store you bought it from and get it replaced. Be sure to take of the selotape beforehand since it will look like the drum kit has been tampered with.
Feb 01, 2009 | Buck Guitar Hero World Tour for for Xbox...
Buck Guitar Hero World Tour for for Xbox 360 Logo
88 people viewed this question
Top Buck Video Game Consoles & Games Experts
dj ese
Level 1 Expert
Person On the...
Level 1 Expert
Are you a Buck Video Game Console and Game Expert? Answer questions, earn points and help others
