Question about Buck Guitar Hero World Tour for for Xbox 360
I had guitar hero since xmas and yellow symbol not working
The wire that connects the yellow symbol is broken completely off the black little thing that goes into the slot. the actual wire is coming out and i stuck it together with sellotape and it worked until it fell off and the wire has come out worse and its all screwed up and it wont go back in no matter how much i do.
everything else works though.
please help me and does anyone know if or where you can get a new yellow symbol? please and thanks for listening.
  • 3 more comments
  • shannon_dood Feb 06, 2009
    it doesnt matter now, my dad managed to fix it, thanks
  • Anonymous Feb 17, 2009
    i have the same problem
    i have the same problem with my symbol...the cord for the yellow symbol ripped out. How did you fix yours?
  • shannon_dood Feb 20, 2009
    hey, am.. my da used an old set of headphones for the wires to replace the broken wire for the yellow symbol and it worked like a star, especially when I put a bit of tape (green,black etc) on a quarter of the senser of the symbol and I only have to barely hit it now.I also put some tape on the red one as it didn't pick up the sound too well.
    I hope this will help, if not, you may have to bring it back to the store and either get it repaired by them, or get a replacement from them.
    Thanks guys.
  • neoanderson May 11, 2010
    Where did you get it from?
  • 51 Answers
How did you break the wire?
The best I can suggest is that since the drum kit is still under warranty, take it back to the store you bought it from and get it replaced. Be sure to take of the selotape beforehand since it will look like the drum kit has been tampered with.
Posted on Feb 13, 2009
Hey, I purchased your Honeywell RTH2510 Thermostat, but I didn't even think to label the wires when I took the old thermostat off. Upon installation of the new Thermostat (2510) the Air Conditioning...
The connections that you really need to reference would be at the air handler itself. That would tell you which wires go outside to the heat pump and which wires go to the air handler. I can however give you some basics that may help.
Heat Pump Wiring
R- Red- 24v power supply. (Usually a jumper between RC/RH)
G- Green- Fan
W- White- Heat (Sometimes W1-W2, first or second stage heat)
Y- Yellow- Cooling (Same applies as above i.e. Y1-Y2)
C- Common (Most people use blue unless it is used for B terminal and sometimes cooling on older 4 wire systems.
B/O- Reversing Valve for heat pump. Either powered heating or powered cooling, depending on system installed.
Aux- Also used for heat.
Note: Considering that the installer had their own way to run all wires, use different wires, connections, etc. This is just a reference to common wiring in the field.
How the most common system is hooked up:
Red wire goes to R terminal
Yellow wire goes to Y1 or Y2 terminal
Green wire goes to G terminal
White wire usually goes to W1 or W2 terminal
Orange or Black wire goes to B/O terminal
Brown wire usually goes to Aux terminal
Blue wire goes to C terminal, unless its being used as stated above.
This is without using a fossil fuel kit or zone control board.
Where do they go from the thermostat?
goes to the air handler transformer or board and goes outside to heat pump to power low voltage controls.
Yellow wire goes straight outside to Y terminals on heat pump unless going to a board inside first.
Green goes to the air handler fan relay.
Common goes to the air handler and outside to heat pump.
Black or Orange will go outside to heat pump terminals for reversing valve.
White usually goes outside to heat pump,and inside to air handler. Will explain reason further down.
Brown will go to the air handler to the heat relay for the emergency heat.
On a call for heat, with a powered cooling system (more common).
The R, Y, and G terminals energize, sending a signal to start the blower and pull in the contactor outside. Note that the Y terminal is usually cooling, but since this is a powered cooling system, the reversing valve is not energized, causing the system to run in heat mode. If you have powered heating, the reversing valve terminal will energize also. Depending on thermostat, if you set the temp substantially higher than room temp, it may kick on the emergency/aux heat to quickly raise the room temp. On a call for emergency/aux heat, the R, G, and E/Aux terminals are energized, turning on the electric/gas heat instead of the heat pump. This comes in handy since the heat pump can only pull so much heat from outside before its not enough to properly warm the house, usually around 30 degrees outside temp. If you are running the heat pump and the system goes into "defrost", the outside unit will send a signal back to the air handler, through the white wire I mentioned earlier, to tell the emergency/aux heat to come on while it is in defrost mode, providing heat whenever needed.
Again, this is just a reference guide to some basic wiring, but hopefully it will tell you where the problem is or at the least, give you a good start. There are variables in which things can change the wiring like a zoning system or fossil fuel kit. Even then, you should be able to get pretty close. Hope this helps and Happy Holidays!
Dec 07, 2013 | Honeywell Programmable Thermostat Heater
How do I wire this thing
Your black is hot and white is neutral. Just follow the symbols on the timer. It's supposed to tell you what connection goes where.
May 06, 2012 | GE Hardware & Accessories
Maytag cse9000ade cooktop. Does anyone have
Hi Greg. Welcome to FixYa. I am Kelly. I have been looking into this for several hours now. Even service manual(s). The only thing I can find is the yellow wire goes from the infinite switch to the right side elements. I don't see a blow on your model so the wiring diagram should be on the bottom of the pan cover. The bad news is I can not tell if it is actually on the bottom or inside the bottom. From everything I can see it appears that the yellow wire would be attached to L1 vs where you currently have it connected i.e neutral. I can not come up with the wiring diagram that is part of your cooktop but all of the other Electric Maytag and Jenn-Aire models show the same thing. Yellow wire from the infinite switch and L1. Take a look at your wiring diagram if you can find it and see if you come up with the same conclusion.
This became one of those solve the mystery questions for me and I literally have been looking at it for about 3 hours now. trying to get something I can safely pass to you that will not damage your unit.
With the yellow wire on neutral currently it would be operating on 110V and have low heat. Placing the yellow wire on L1 (Left) should get 208V to the right side burners. Again.. take a look at the schematic / wiring diagram that is attached to your unit.
This is the best I can do from here. The users manuals I have found for your cooktop are in several languages. ENGLISH is not one of them :(
May 03, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
Broken yellow pad
just go but a new one that's the only choice!
Sep 03, 2009 | Activision Guitar Hero World Tour Guitar...
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Both symbol wires broken
i agree withe you about geting an electricin but before you get him maybe something wrong with the symbol wires or the television
Jun 27, 2009 | Nintendo Rock Band for Wii
VR3 cd 400 where to get wiring plug to go in back of player
Do you need a wiring harness for the back of the unit? All you have to do is google "wiring harness for vr3 cd400 and you will have allot of options to choose from. If you connected the red which is 12v +, yellow connects to 12v for radio memory, and black goes to ground. Brown is for external amp turn on. Check to make sure your connections are correct. Do you have an adapter harness that plugs into the factory radio harness? You can get one from Wal-Mart or best buy or online. So you don't have to cut/splice into the wiring harness coming from the stock radio.
Aug 25, 2017 | Virtual Reality Sound VR3 CD Player w/ USB...
Buck Guitar Hero World Tour for for Xbox 360 Logo
321 people viewed this question
Top Buck Video Game Consoles & Games Experts
dj ese
Level 1 Expert
Person On the...
Level 1 Expert
Are you a Buck Video Game Console and Game Expert? Answer questions, earn points and help others
