Question about Exercise & Fitness
Black ooze! I have Salomon X Scream monocoque Skis. I have just returned from skiing and was giving them a wax before putting them away for the year. The skis have Prolink strengthening front and back and I noticed black sticky ooze emanating from the Prolink joints. These were easily cleansed by use of white spirit. 1) Is this a problem? 2) Do the Prolinks contain some sort of oil? 3) Do I have to have this rectified before skiing again? Thanks for your help.
  • Anonymous Mar 12, 2009
    I also just returned from a ski trip and found this mysterious black
    ooze coming from the Prolink joints of my Salomon X Scream series skis.
  • 29 Answers
SOURCE: Excessive white smoke from 2-strokes
HELLO;Im assumeing that both have several hours on them,if so it possibly could be your rings and or the fuel mix your useing. Try and reajust your carbs. ( process of alimination), then run them and see if there is any change. If not, get a hold of me if you would like and we can try some thing else. wwwgreasy@q.com.
Posted on Oct 04, 2009
wayneman01
  • 301 Answers
SOURCE: hi, The rectifier of my honda CBR 1000f year of
The three yellow wires carry AC current from the generator to the rectifier. The rectifier turns this AC current into DC current and sends it back to the battery through the red and the black wires. I am not certain what the purpose of the 7th wire is on the new rectifier except that it may be used for thermal sensing of the rectifier - which would explain why it is mounted tight to the unit.
Of all the components that make up your Honda's charging system, the rectifier is the most likely to fail. The reason is usually excess temperature buildup - which causes the diodes inside it to fail. If you are running extra electrical accessories on your bike, this can cause the rectifier to overheat and die. Same thing if you frequently let the bike sit until the battery goes dead, the rectifier works hard to recharge it each time.
You may be able to extend the life of the unit by avoiding things that put extra strain on it, as described above. Also make sure there's nothing covering the cooling fins on the rectifier - or blocking airflow to it (dirt, that extra pair of gloves stuffed next to it, etc.).
Finally, there's one thing that will kill the rectifier instantly: connecting the battery cables backwards. That'll fry it every time.
Posted on Jan 15, 2010
  • 5 Answers
SOURCE: Vertical adjustment on front binding. Salomon S810 Ti
If you can adjust vertical pressure then you should adjust it as follows.
Put a piece of normal paper (like A4 printer paper) on the toe bit (and heel for that matter) and clip in the boot so that the paper sits between the boot sole and the binding base surface. You should be able to pull the paper out from between the boot and binding without ripping the paper, but obviously without there being a noticeable gap.
If in doubt take it to a ski tech, a bit of cash might save you a broken leg! They might even be able to help you or advise free of charge.
Posted on Jan 27, 2010
SOURCE: YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Posted on Jun 30, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordic track Ski
Dear Sir:
The best way is you go to the next web page:
www.nordictrack.com you must give serial number+modell
whoever i will give another alternative.
www.fitnessrepairparts.com
www.gympart.com
Posted on Nov 13, 2011
Ski replacement
take your pick :>)
Snowmobile Skis (Universal) - BikeBandit.com
www.bikebandit.com > Aftermarket Parts > Tracks & Skis Items 1 - 20 of 20 - ... at BikeBandit.com. The Web's most trusted source for Snowmobile Skis (Universal). ... AFTERMARKET PARTS · Shop Aftermarket Parts by ...
Camoplast Camoski Plastic Ski Kits ' Snowmobile Parts ...
www.mfgsupply.com > ... > Skis and Accessories. > Skis & Ski Shocks Camoplast technologically advanced blow-molded Snowmobile ski. Lightest weight ski on the replacement market.
OEM Snowmobile Parts and Snowmobile Accessories for ...
www.dirtcheapsnow.com/ Get your motor going with genuine OEM Snowmobile parts and aftermarket accessories at the best price for your Polaris, Ski-Doo, Arctic Cat, and Yamaha ...
Snowmobile Replacement Body Parts - Dennis Kirk, Inc.
https://www.denniskirk.com/snowmobile/replacement-body-parts Results 1 - 38 of 191 - Shop the best selection of Snowmobile Replacement Body Parts at Dennis Kirk for the lowest prices. FREE SHIPPING on orders over $89 ...
Aftermarket Ski Options - Snowmobile.com
www.snowmobile.com > Products Oct 16, 2008 - Aftermarket Ski Options: Most snowmobilers rarely give their sled's skis a second thought until that day when the sled seems to have a mind of ...
Jan 15, 2016 | Winter Sports
My Dept56 animated ski mountain. The skiers seem to heavy for the magnets in the ski run
Cut the friction on the skis or ski slope, use wax or soap to cut down on friction
Dec 16, 2014 | Sport & Outdoor - Others
Uses for Liquid paraffin
waxing skis, making your own recipe of lip balm, sealing wood furniture, sealing cutting boards, making your own liquid candle
Nov 28, 2013 | Cell Phones
What different types of cross-country skis are there?
there are two types
1. general touring skis -these are for track skiing. They are long, narrow, and light compared to metal-edge skis, making them more efficient and very fast. This makes them better to use for the groomed trails.
2. metal-edge skis -for skiing out-of-track or on steeper terrain. They are heavier than touring skis and have metal edges to grip the snow and ice. The edges also help with turning on steep slopes. They are meant for deep snow and icy terrain. They are wider in order to be more stable.
Feb 27, 2013 | Winter Sports
What are the different types of water-skis?
The different types of water-skis are: combination pairs, slalom skis (one ski), and trick skis. Combination pairs are the most popular type and are used by beginners due to the ease of their use. Slalom skis are more advanced than combination pairs, which make them more difficult to learn. Good thing about them is that you can reach a greater speed with them and making sharp turns. Trick skis are used by individuals who want perform all kinds of tricks (jumping, spinning, and other tricks).
Feb 06, 2013 | Water Sport
What is water-skiing?
Water-skiing is a sport activity where an individual has to hold on to a ski-rope while being towed by a powerboat. Using one or two skis, the individual rides the water. Beginners usually start off wearing two skis, while more advanced individuals wear just one.
Jan 10, 2013 | Water Sport
Refinish the top side of K2 skis?
If there is major damage that could affect the structure of the ski there is really no one who can fix it and i wouldn't continue skiing on them. If you are just trying to make the skis look nice on top try any oil based cleaner if that doesn't work give them a thin coat of epoxy. why does the condition of the tops of the skis matter anyway?
Mar 21, 2010 | Sport & Outdoor - Others
Nov 07, 2009 | Rossignol Used Freeride X 05 Skis with...
We have used 1999 Jeep GCL. Key will not turn, nor can be removed. Purchased a used steering column @ salvage yard. Vehicle is at a repair shop. He replaced the steering column, started car, it runs for a...
you know the fuel pressure regulator could cause your vehicle to shut off after a few sec but then you should be able to start it a few secs later then it will do the same thing..computers can be reset unless they are burnt out..
Dec 04, 2008 | 1999 Jeep Cherokee
Exercise & Fitness Logo
140 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
