How to hookup dvr cable hd box to dvd player with surround sound
Dvr is hookedup to tv sharp hdtv
    Scholar:
  • 93 Answers
If you have HDMI on the dvr and the tv use this cable connection this will handle audio and the video at it`s best, if you do not have HDMI, use the 3 component video outputs to the tv and a digital audio connection from the dvr to the tv
Posted on Feb 01, 2009
My Sharp Aquos LCD TV 40E77U is working on the analog input but won't detect HDMI inputs?
This set MAY require or have available a software upgrade for this issue.
Contact Sharp to see if they have it or if this is an issue in their database that is common.
Mar 20, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp tv opc light stays on
I have an opc light that stays on. My cable channel input will come on briefly then picture and sound shut off but the dvr works just fine.
May 01, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
Need remote code to turn on a motorola dvr using my sharp tv remote
Motorola DVR 0093 0055
Try those and see how you go
Please rate my help++++Thanks for using FIXYA
Jun 30, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sound doesnt come out of tv when hookedup to cable box sharp tv
You must use the video and audio with their own separate cables. The sound is separate.
If you are following proper procedure, then you should contact the tech support for your set to find out if there is a defect somewhere.
Jerry G.
Nov 14, 2009 | Sharp LC-32SB24U 32 in. LCD TV
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
472 people viewed this question
 Grubhead
Grubhead
