Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
No Audio on ECS 6100SM-M2 mobo d
Just purchased the above mobo . all ok except i cannot get the audio to install what ever i do. new drivers . bios update , disk is useless . any one got any ideas
  • 30 Answers
Go to the Startup Bios Configuration Utility By Presing Specific hotkey. Probanly you having Audio Device as Following
Realtek ALC660/ALC662 6-channel audio Enable or Reinstall Driver As link given here >>> http://www.esoft.web.id/go/WDM_R210.exe
Hope you will have good result
Regards
Posted on Feb 01, 2009
  • Rizwan Noori Feb 01, 2009
    if you have another Problem don't hesitate to contact me
Iam running xp2 my notherboard is pm800-m2 i found out that there is no sounds even i go to dxdiag to run sound testing but no to avial...i wonder if u could help what driver should i install this...
Most probably the audio/sound devices drivers are not properly installed or check your CMOS Bios to see the on board devices Audio devices is "ENABLED"!!
Check your "Devices Manager" to confirm whether your Audio devices for the motherboard is properly or correctly installed. Ensured that your speaker is properly plug into the correct output port.
If you do need the Audio drivers for your ECS motherboard, you can download the from the ECS Site.
Hope it helps.
Aug 26, 2010 | Computers & Internet
After downloading drivers from ECS site for geforce 6100 sm-m i still do not have ethernet adapter. Also other pci bridge device is missing. In XP
since your not able to install the drivers..
Broadcom AC131 10/100 driver is the same as nforce 430/410
http://www.nvidia.com/object/nforce_nf4_430_410_winxp32_8.26.html
or
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
then try installing Uniblue DriverScanner or Driver Genius Professional Edition so you can get all the other drivers for you motherboard
you can also try to update your bios only for ecs 6100sm-m mobo
http://drivers.softpedia.com/get/BIOS/ECS/ECS-GeForce6100SM-M-V10-10A-BIOS-070906.shtml
hope this helps..
Dec 31, 2009 | EliteGroup GeForce 6100SM-M Motherboard
I need manual instructions for instalation of K8M800-M2 Motherboard
go to ecs.com elitegroup or google K8M800-M2 THEN SELECT ECS SITE mobo drivers bios and manual all available
Dec 15, 2009 | EliteGroup K8M800-M2 Motherboard
Installed Intel P4 630 CPU on ECS P4M800-M7 V3.1 mobo. Cannot do POST. The mobo runs fine with Intel Celeron 326 fine.
Hello Mafatbhai, What beeps are you getting at POST?
Here is a list of BIOS beep codes.
http://www.computerhope.com/beep.htm
Well the mobo should not have any problems with the new CPU. Please ensure though that you have removed the CMOS battery to reset it. I have included a link to ECS for your specific board. Download and install all of the available updates starting with the drivers and then the BIOS updates.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailID=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jul 11, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Audio driver
http://download.softpedia.com/dl/67726aafea796ee43af7c61c08816bbc/4a479ec8/100030373/software/system/info/everestultimate502.exe
<<download this then get back to me once you have installed it
Jun 28, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
ECS P4M900T-M2 Motherboard windows xp service pack 3 audio driver
are you all running vista or xp ? if xp this sound chip will only work with sp1 installed as it is designed for vista
Nov 07, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
ECS 6100sm-m
Download WD's software to test & setup drive. Try windows install again.
WD's link; http://support.wdc.com/download/index.asp?cxml=n
Mike
Apr 25, 2008 | EliteGroup GeForce 6100SM-M Motherboard
Audio driver
The GA-7N400 Pro 2 uses the Realtek ALC650/655 Audio AC'97 Codec for onboard sound.
Here is the site you'll need to go to.
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1756
I would recommend that you be sure to install ALL of the basic drivers. This includes not only the audio drivers but the CHIPSET drivers as well. Especially since this is an nForce 2 board. Those boards are rather touchy. Chipset drivers will keep the system more stable and help it to run more efficiently.
You may also download more up-to-date drivers for the audio from RealTek's website at:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=23&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false#AC
This should be easy... :)
Cyryl
Nov 04, 2007 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
GeForce 6100SM-M Motherboard (no Audio )
I down loaded Realtek HD audio drivers from
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Driver&DetailDesc=GeForce6100SM-M(V1.0/1.0A)&CategoryID=1&MenuID=75&LanID=0
Oct 24, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
524 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
