Question about SanDisk Sansa m230 MP3 Player
Deleted the config,audible and all the default files
Hi, I was not able to delete the existing music files, since I was not able to find those folders.So I deleted complete disk,but still i m able to hear the existing music files and the problem is that i m not able to record new ones.I m really frustrated,can any one help me in soving the problem.
1. Go to the Settings menu 2. Change USB from whatever it says now to the other option. I.e., if Auto Detect >> MSC, if MSC >> Auto detect 3. Reconnect to the computer. Now you should see the songs. 4. If still you can't the songs, format the drive as described in the video tutorials on the product site Almost sure this will help you. Regards, Karo
Posted on Sep 14, 2007
SOURCE:
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
How do i reset my at-8000s switch to factory default by using command
follow this step
KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
Delete startup-config [y/n]? y
Startup file was deleted
KIMIA#
User Name:manager
Password:friend
console#
console#
Mar 29, 2012 | Allied Telesyn Allied Telesis...
Hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you...
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
These 5 commands will delete the current, corrupt registry hives.
These 5 commands will copy the pristine, uncorrupted hives into your system.
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Sansa mp3 player m230...
have you tried opening the files in a music player? it sounds like you are just accessing the file folders. try opening it with windows media player or something like that.
Aug 27, 2008 | SanDisk Sansa m230 MP3 Player
Delete more than 4.omb
I think the problem is that you deleted one of the syst. file on the RCA Lyra.. These are the files you need to have in order to make the mp3 player work.
Setting.dat
Music.sec
Time.dat
music.lib
and the 4 folders (Voice) (line-in) (FM) (audible)
Nov 27, 2007 | RCA Lyra RD2217 MP3 Player
Deleting songs
You need to delete songs using the music software provided with the mp3 player.Access the library and then delete them in there.
Sep 28, 2007 | SanDisk Sansa m230 MP3 Player
Not able to delete existing files
Try to Format it, here are the steps: 1. Click on "My Computer" 2. Right click on the sansa icon 3. Pick Format. Hope this helps, D.
Aug 01, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
