Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Maytag MFI2568AEW Would like to know how to change the water filter on this model. Can't find the user manual. Would appreciate any help.
  • 410 Answers
The filter for this unit is located in teh upper right hand corner of the refrig ceiling. there is a thumb latch on the cover release teh cover and you will expose the filter. turn the filter 1/4 turn counter clockwise to release. then reinstall new filter. be sure to run approx. 1/2 gallon of water thru the dispenser after replacing filter to purge air from the lines.
p.s the icemaker and water disp will not work without the filter in place. Have a Great Day! peyton
Posted on Feb 01, 2009
  • peyton thompson
    peyton thompson Feb 01, 2009
    Thank you for the great rating i look forward to helping you in the future! Peyton
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
I have a Maytag French Door Bottom Freezer / Refrigerator. Model MFI2568AEW. I changed the water filter today and 10 seconds after installing the new filter it started making a very loud noise like
Sounds like water hammer, has the water supply got it's own shut-off valve behind the fridge or in the basement ? Try shutting the valve then open it just a little. Perhaps the water supply was opened fully after installing the new filter.
Oct 15, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag french door handles loose
The best way to tighten the handels is to see the instructions listed in your User Manual=>
MFI2568AEW User Instructions If you do not have the free Adobe Acrobat Reader click here=> Adobe Reader X (10.1.1) first. Once you scroll down to page 7 in the PDF you can see the set screws that are hiding in a small opening under each side of handle. Below you can also click on the Maytag Logo and it will take you to the page that ask for model number. If you have questions after reading the instructions in your Maytag User Manual please let me know HERE, Thanks Sea Breeze
If helpful please rate my solution. Thank You
sea_breeze_264.jpg Manuals
Oct 18, 2011 | Maytag MFI2568AE Side by Side French Door...
My water despencer suddenly stops working after every use and will only give about 5 ounces of water then stops.Can any one help me with this problem please.
Hello, Thank You for using FixYa. I will be helping you today.Did you try replacing the water filter? It sounds like a bad filter or low water pressure to the unit.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Change water filter. now water is running slow. put old filter back in, still running slow. ICE2O
Hello, Thank You for using FixYa. I will be helping you today.The only thing that can cause slow water is low water pressure from the house line a bad filter or a frozen water line or tank. Most of the time its the house water supply it should be at least 35psi.
Jun 10, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Filter needs changing
You don't need a plumber. The filter is located inside the fresh food section, in top-right corner. There is an elongated cover with a tab in front. Press the tab towards the back of the fridge slightly and pull the cover front down. There is your filter. No need to turn the water off either. Just twist the filter counterclockwise and it will pop off.
The part number of the filter is UKF8001, can be purchased in any appliance parts store, for example here. "New10"coupon takes 10% off.
Nov 09, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Water filter compartment leaking
If you have already replaced the filter and you can see the housing is still leaking, You have to replace the housing and water tank as an assembly (12956202). Make sure you verify it's the filter housing leaking, and not a fitting at the water valve which is right behind the plastic cover around and below the filter housing.
Apr 28, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
341 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
