Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
Used chest freezer not cooling
I purchased a used Kenmore 23cu.ft chest freezer. The owner claims to have tested it before advertising. The compressor seems run fine and turns off when the thermostate is turned to zero. I have had it plugged in for two days with no results. Any suggestions before I return this to the seller.
    Novelist:
  • 176 Answers
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
Posted on Feb 01, 2009
  • 410 Answers
Chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
How to fix a chest freezer by kenmore
The clicking is the compressor trying to start. Probably a better bet to replace rather than try to repair with new compressor and electrics, drier and gas.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore freezer model C10BLEM blows circuits. I just bought it used. At original owners it worked well. I plug it in and after a couple of minutes it blows the circuit. I plugged it into the furnace...
If it is a chest freezer, almost certainly it is the compressor. Only way to check is to pull the power plug out then remove the compressor wires from the terminals then make sure it doesent touch the frame of the freezer, then plug the power back in and see if the power trips again. If not, there is the problem.
Aug 22, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Start up current draw
Lock motor Amps ( LMA ) is the current draw when the compressor starts.This draw of current is less then 1sec.The amp amount shoud be on the compressor Name Plate.This amp draw is also the amps used when the compressor goes bad and locks up then the overload kicks out.
May 21, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
I have a freezer chest the compressor comes on but it never cools
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Nov 10, 2009 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Dec 23, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore chest freezer.
Most likely a bad compressor. You could try a new relay on it first.
Nov 21, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
781 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
