Question about KDS Valiant 6380iPTD-01 Notebook
F22 on my vaillant boiler turbo max
Pls can you tell me what f22 means on my boiler
  • ANOINTEDUK Mar 01, 2009
    f22 is flashing on my boiler too, no hot water....HELP!!
Hi Guy's,
The answer is that your system is out of water pressure.
Usually there is a nob on the right under the base of the unit near to the small dial to the right of the front cover.
To enable the system to work correctly the needle on this dial should be in the Grey, about midway position.
Currently with fault F22 this will be lower to below the Grey and on the needle.
To bring the pressure back to the correct position, you need to turn this nob until you hear the water entering the system, KEEP AN EYE ON THE DIAL AND TURN THE WATER OFF AGAIN WITH THIS NOB ONCE THE DIAL IS IN THE CORRECT GREY POSITION AS MENTIONED ABOVE. DO NOT OVER FILL THE SYSTEM. I suggest you check this every six months or so.
Once this is corrected your unit will light up again.
Best of luck. Mike. N.
Posted on May 22, 2009
Above isn't the cause, this seems to be a never ending problem with vaillant boilers, I've had Vaillant engineer out and he's changed just about every part on the boiler. Water pressure is where it should be and still, up comes F22. The only way this can be repaired is by replacing the PCB printed circuit board, this does work, but because it's expensive it is the last resort for a contract repairman.
Posted on May 31, 2009
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
My combination boiler vaillant turbo max is not building up presure what can I do ?
Check the warning pipe to see if water is coming out. If it is then the pressure relief valve is passing and will require cleaning\replacing. If the water in the system is dirty then the capillary tube to the pressure gauge may be blocked this normally means changing the gauge. If neither of those are satisfactory then you may have a leak on the heating system or heat exchanger.
If the pressure is going up but dropping off when the boiler cools down this indicates the expansion vessel diaphragm needs recharging or replacing
Vaillant error F22
The water pressure is too low. Set it for 1.5 - 2.0 BAR.
Mar 05, 2014 | Computers & Internet
My valliant combi boiler 4 years old wont start up fault code 22 flashes up
F22 means low water pressure. Check the pressure dial on the boiler and adjust using the link pipe and valves.
Nov 15, 2013 | Computers & Internet
Keeps saying f22 when trying to start wash
F22 means you have a door lock issue -- not sure what these other guys are telling you but you need to unlock your door to correct the problem. Remove the lower kick panel by taking out the screws on the bottom. reach up on the right side---attached to the door latch is a 2 inch long plastic bar you need to pull directly down to unlock the door. After this disconnect the power to your machine for 1 minute and reconnect the power. If the error comes back replace your door lock assembly. Here is the part to order. Below is a video to show you how to replace the lock.
Dec 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does f 22 code mean
if you could tell me the make & model I could tell you what the code fault is f22 applys to 8 different makes of machine and they all mean different faults
Dec 02, 2011 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F5 keeps coming up on my boiler when i turn it on could you tell me what F5 means please
Who is the maker of your boiler? Also, I need a model number so I can look up the info.
Dec 12, 2010 | Heating & Cooling
F22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
May 11, 2010 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
5,763 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
