Question about Dryers
White knight dryer 797c drum wont turn
Hi, i have a condenser dryer which is heating up fine but the drum has stopped turning any ideas what the main cause of this could be?
Many thanks
  • 1 more comment
  • michaela spiezick Feb 01, 2009
    hi, just checked the belt and it is still on, it did attempt to turn but couldn't manage it, it is also very noisy. Not sure if need to attempt replacing the belt or if it could be something else
    Many thanks
  • jo37fem Apr 19, 2009
    dryer heats up but drum wont turn, i can move it by hand but it just wont move by itself
  • jo37fem May 11, 2010
    cant find the belt despite taking top and back off
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Try this
Posted on May 10, 2010
    President:
  • 2,559 Answers
Sounds like the belt may have broken
please rate this a fixya
Posted on Feb 01, 2009
  • Randy Hough
    Randy Hough Feb 01, 2009
    If you can't turn the belt or the drum,the bearings may be locked up and need replacing.
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
White knight
take the plug
does it make a buzzing sound or do you hear the motor turning
or if you spin the drum by hand it spins freely if it spins freely check the belt and jockey wheels
Dec 08, 2013 | Washing Machines
Hi my dryer is heating up but the drum not turning help its a white knight small tumble dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Dryers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Mar 25, 2010 | Dryers
White Knight 44AW electrics problem
You may have a short in the system, make sure your breaker is rated high enough to support the dryer
Oct 06, 2009 | Abbaka White Knight 44AW Electric Dryer
Tumble dryer drum only starts when i start it first by hand
starter capacitor went bad on motor... replace
Mar 12, 2009 | Dryers
Dryers Logo
284 people viewed this question
Top Dryers Experts
