Question about Peg Perego IGED1084 Santa Fe Train
Will not go.
Charged up the battery but nothing is happening
  • tedtwice Mar 17, 2009
    Battery is fully charged.
    Full voltage available at terminal ends when switch is pressed.
    When terminals are connected motor does no react. voltage at motor is only 0.5v when switch is pressed.
  • 60 Answers
The battery is probably bad, this is very common and happens often if the battery is not charged often.  Call peg perego directly for a new battery.
Posted on Mar 11, 2009
Plugged in charged battery on my century 7004 racing boat and put in water but nothing happens
hi
you need to check the voltage of the battery to ensure that it is charged. (use a voltmeter or multimeter set to an appropriate range according to the expected battery voltage).
if the battery is charged, check all the connections to the battery and inside the machine are firm and secure.
if the battery is not charged, try recharging it again, and recheck, also check the charger is working properly.
hope this is helpful, if so would you please register that with fixya
cheers
Jan 21, 2015 | Computers & Internet
I turn the key and nothing happens.
check for corrosion runnig inside battery cable
Apr 28, 2013 | Cub Cadet Garden
Optura 60 cannot be turned on
Whether you think the battery is fully charged or not this sounds like a defective battery problem. Have the battery checked.
May 05, 2017 | Canon Optura 60 Mini DV Digital Camcorder
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Turn ignition on,nothing happens,battery is fully charged.
How do you know battery is fully charged?? Do you have a load tester or at least a volt meter to test it?? Seriously, the battery may appear to be charged and show 12-13Volts on a meter, but fail when placed under load.
Check also the bolts on the battery terminals.... they may be loose.
Do you get any display on the dash? EWS error??
Aug 16, 2010 | 2008 BMW R 1200 GS Adventure
Just bought my dad a second hand go go 3 wheel elite scooter
Hi Linda. Sometimes if there is a blown fuse or faulty connector on the battery leads, the charger thinks the batteries are charged as the voltage coming out of the charger rises to the high level. Some chargers will cut out if this happens. It is probably not the charger.
Make sure the batteries are plugged in correctly, sometimes during transport they will get knocked and become disconnected.
Also make sure that the battery terminals are not loose where the wires connect to the batteries.
Good luck. Neil.
May 21, 2010 | Pride Mobility Products GoGo Ultra X...
Peg Perego IGED1084 Santa Fe Train Logo
300 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
