Question about Lexmark All-in-One Printer with PictBridge
Can't find settings to make scan/copy darker
The pritner works fine as a printer. It will scan and copy, but the copy pritn out is very faint. I'm just trying to make it darker, but can't find any settings anywhere. Anyone got any ideas?
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: printer will not copy or scan but will print
Hi John, Even if you have deleted them by accident, you can always reinstall using the CD that came with the printer/scanner. If you want to do a clean install, then you would probably have to uninstall also the printer drivers and start from scratch. You may also not uninstall and set it up again. If you go this route, it is also possible that you will have two icons in your printer folder of the same hp printer. Assuming nothing is wrong with the hp, the scanner drivers and app would be reinstalled and presumably you will have access now to your copy/scan functions. Should like to download the installer/driver for you printer/scanner, it is available at (http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&product=79488&lc=en&jumpid=reg_R1002_USEN). You would have to select your operating system. Hope this works for you. Pls post again how things turn up. Kind regards.
Posted on May 29, 2007
  • 3 Answers
SOURCE: No Copies
It could possibly be your main charge assembly. If there is no charge on your drum, it can lead to blank copies.
Posted on Jun 27, 2008
  • 53 Answers
SOURCE: Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
Posted on May 18, 2009
SOURCE: Lexmark X9350 will not scan or copy
Hi, have you had any luck repairing this? I also had this problem. I rang Lexmark support who, after 45min on phone, decided to send me a new machine. They did not want the old one back so I intend to try and repair it when I have time. I reckon the x9350 are prone to scan head problems as mine was making strange noises before it packed up and I have seen other reports of problems on various forums.
Posted on Aug 03, 2009
Copying is very light while scan print fine
Unfortunately that is typical. You can set the copies to be darker, but often that just introduces gray areas that should be white.
Better to just scan and then print the pdf.
Jul 04, 2016 | Office Equipment & Supplies
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
The printer prints part of a page from some sites, some site the whole doc and some site a enpty page
solution 1>
click on start go to control panel go to pritners adn faxes or pritners in vista or win 7. then click on add a pritner. add a local pritner then hit next. choose existing port usb vertual pritner port. then hit next. under manufacturer select hp and under prtiners select deskjet 990c. hit next. do not share this pritner. finish add printer wizard. try pritning
solution 2>
click on start then click on run in open box type
%temp% hit enter. in vista enter %temp% in start search and hit enter it will open temp folder with lot of foledr optio0n find low folder adn delete it permanently then restart computer
Dec 16, 2009 | HP DeskJet 5550 InkJet Printer
Computer says it cannot initialize the scanner
insert installation cd adn perform add a device. or if your pritner is connected to bluetooth it will not scan. as blue tooth signal is not strong enough to scan from pritner to computer. it works on some but don't work on all blue tooth
Dec 15, 2009 | HP Photosmart C5280 Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Canon MP730 Pritner
nope..sounds like a communications issue...maybe a new cable?
http://tinyurl.com/6qcpgy
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
333 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
